Best way to reattach glass door unit to fiberglass shower wall?
Discussion in 'Shower & Bathtub Forum & Blog' started by nightowl, Jan 10, 2009.
  1. nightowl
    nightowl New Member
    Jan 10, 2009
    The top mounting screw holding my glass door unit to the fiberglass shower wall has pulled loose. The other mounting screws are fine but this missing one is allowing the shower door to drag slightly which has worn out the rubber stripping at the bottom (which alerted me to the screw problem).
    I've tried re-tightening the screw but it just turns in place. I've inserted a small wire into the screw hole and can't feel anything substantial for the screw to tap into (i.e. stud or other platform).
    I've considering using a anchor style screw along the lines of what I would use to attach a shelf to sheet rock. However, I'm worried it will put to much stress on the fiberglass wall, causing it to crack or break.
    Does anyone have any suggestions on what would be the best method/option for making this repair?
  2. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    There are two methods that I am familiar with to attach something to a hollow wall. The good old Molly and a toggle bolt. I'd probably consider the Molly as my first choice as it does not require a hole as large as the toggle bolt, but either should work. I'd replace the screw in either devise with stainless steel.
  4. nightowl
    nightowl New Member
    Jan 10, 2009
    Should I be concerned about either one pulling back through the fiberglass wall or causing stress cracks down the road?
  5. jimbo
    jimbo Plumber
    Yes, but you do not have a lot of options. Ideally, there should have been blocking installed to attach shower doors, grab bars, etc.
  6. chrisexv6
    chrisexv6 Member
    Oct 6, 2008
    Check out www.toggler.com for some possible products.
    Ive basically tossed all my red/yellow/blue plastic wall inserts and use Toggler for everything now. They are more expensive (and sometimes harder to come by), but once Ive put a Toggler in a wall Ive never had to replace it.
    In fact I just replaced one of the inserts holding up my shower door tracks because it pushed thru during installation. Toggler was slightly oversized for the same hole and holds better anyway.
  7. jadnashua
    Depending on the width of the frame, check out www.wingits.com. They require a bit hole, but really hold.
Similar Threads: Best reattach
Shower & Bathtub Forum & Blog Best type of shower mixing valve / highrise bldg with poor pressure balance Dec 21, 2016
Shower & Bathtub Forum & Blog Best bathroom vent fan with light? Jun 16, 2016
Shower & Bathtub Forum & Blog Best soffit vent w/ anti-backdraft, for bathroom vent fan? Jun 16, 2016
Shower & Bathtub Forum & Blog Best option for shimming Cambridge tub level Sep 30, 2015
Shower & Bathtub Forum & Blog What kind of tile is this and best way to clean the rust? Sep 14, 2015
