Best "roto Zip"
the pelon
What is the best "roto zip" type tool to buy. I know there are several different companies that now make them. What is the best overall tool to buy. Thanks, Pete
Alectrician
DIY Senior Member
I like the Rotozip brand. It also has a grinding wheel attachment.
PEW
DIY Senior Member
I also have a RotoZip brand which I use a lot. But, I also have a Fein Multimaster which is also great, does a lot without all the dirt of the RotoZip. They both can do things the other can't, so both are very useful.
AZ Contractor
Phoenix, AZ
I have the cordless RotoZip. It works well for smaller applications.
I also have the corded Dewalt hole saw. I use it less but it also works well.
roto zip
The bits and accessories are generic, so ANY device that spins them, such as a Dremel Tool will do the same job. The difference is in how the tool feels in your hand.
Teamo
Massachusetts
I have the rotozip as well as the dremel. They are two different tools. The dremel is only good for very small jobs. The Rotozip has a lot more power and can do heavier work such as grinding block and tile.
There are a lot of small routers out there. Rotozip probably has a larger variety of add-on accessories. Check how many amps or watts the thing draws...larger numbers mean more power. See which one fits your hand best.
