Bell Gossett Red Circ Pump Flange Leak
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by JerseyShore, Dec 18, 2012.
  1. JerseyShore
    JerseyShore New Member
    Dec 18, 2012
    New Jersey
    Hi... I have an old Bell and Gossett red circulator pump for our baseboard heating system. Pump is old, but runs fine. As you can see, ump is vertically mounted.
    Despite having two plumbers change gaskets, the lower flange gasket still seeps and leaks. Last week, I paid $168 for a plumber to change both gaskets. The upper gasket is fine, but after a week, the lower gasket has developed seepage and small droplets of water are beginning to appear. I tighted the bolts as much as I could.
    Both gaskets are not BG OEM, I noticed on **** the BG pump comes with a heavier black gasket.
    This has been driving me crazy for a number of years, so I would appreciate any advice on how to deal with this annoying problem.
  2. johnjh2o1
    johnjh2o1 Plumbing Contractor for 49 years
    Aug 9, 2009
    Retired
    Florida
  4. JerseyShore
    Dec 18, 2012
    New Jersey
  5. MASTERPLUMB777
    MASTERPLUMB777 Member
    Aug 6, 2007
    Retired Master Plumber
    Texas
    Yes that is it !
  6. JerseyShore
    Dec 18, 2012
    New Jersey
    Today I placed an order for B&G Series 100 gasket set 118363.
    I am looking for a NEW plumber to do some 2013 projects, so I will replace the wrong gaskets with these. Ouch! Live and learn!
    Thanks once again!!!
  7. Tom Sawyer
    Tom Sawyer In the Trades
    Nov 29, 2010
    Maine
    That's a b&g 100 and they didn't have the recessed gaskets. If the ones you have are leaking it's probably because they flange is not clean, cracked or misaligned. I have used hundreds of those gaskets over the years. They are not the problem
  8. JerseyShore
    Dec 18, 2012
    New Jersey
    Thanks for your reply....following up on MACPLUMB, I checked the B&G product info from MACPLUMB's State Supply link, the B&G site, and pulled up the gaskets from ****.....all state they are for the 100 Series? I watch plumbers to learn and the plumber wire brushed the mating surface, used pipe dope, looks aligned to me, and I saw the circular recess MACPLUMB is referring to.
  9. hj
    The B&G 100 DOES have the groove for the ring gaskets, (it is in the pump's body, not the flange), just like most of their other ones. They do not use face gaskets like the ones that were used here. THe problem with face gaskets is that they need perfectly flat surfaces to seal, but tightening the bolts on those thin flanges can "warp" them.
  10. JerseyShore
    Dec 18, 2012
    New Jersey
    One last question.... should pipe dope be used on the metal flanges?
    Thanks
  11. johnjh2o1
    Aug 9, 2009
    Retired
    Florida
    No need to use pipe dope. Just be sure that the flange is clean.
    John
  12. JerseyShore
    Dec 18, 2012
    New Jersey
    Thanks, John. Sorry, the State Supply link was yours, no coffee yet when I checked this site.
Similar Threads: Bell Gossett
Plumbing Forum, Professional & DIY Advice K-875 Bellweather Dec 5, 2016
Plumbing Forum, Professional & DIY Advice Kohler K-560 Bellera Pulldown Kitchen Faucet Oct 15, 2016
Plumbing Forum, Professional & DIY Advice Belly in a 4" Drain Line Jul 6, 2016
Plumbing Forum, Professional & DIY Advice Who Rents ProPex Expander Tools in the Seattle - Bellingham Area? Apr 7, 2016
Plumbing Forum, Professional & DIY Advice kitchen sink, Belle Foret BFF3KITWH Apron Front Kitchen Dec 12, 2012
