Bathtub drain need "p" trap? Septic smell
Discussion in 'Shower & Bathtub Forum & Blog' started by Bebo800, May 4, 2013.
  1. Bebo800
    Bebo800 New Member
    May 4, 2013
    Chattanooga, TN
    I live in a 1950's brick rancher and we've noticed a sulpher/dead smell that comes and goes. I pin pointed it down to the basement level bathtub area. So I tore out the wall half expecting an armadillo or mole nest, but instead noticed the tub and toilet drain going down through the slab at this location, but no "p" trap on the bathtub drain. We have a septic tank because we are below graid for city sewer, so do you think it's just the septic smell coming up the tub drain? Has anyone encountered this, what was it and what did you do about it?
  2. asktom
    asktom Member
    Nov 9, 2009
    Victor, MT
    The tub needs a trap.
  4. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    Tuba/shower P traps are usually under the slab so it's a bit tricky to see. Take the strainer cover off of the drain and use a flashlight to look down. If there is a trap, you should see water. If there is no trap (pretty unlikely since all drains are supposed to have a P trap) then you have a problem that is probably beyond DIY. The tub will have to be removed, the slab cut open, and a trap installed. It might very well be a can of worms that a DIY would be in deep doodoo attempting.
  5. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
    Perhaps the water evaporated from the trap if the tub doesn't get used.
    Perhaps there is bacteria present causing the smell.
Similar Threads: Bathtub drain
Shower & Bathtub Forum & Blog Drain Flange won't seal to bathtub Dec 21, 2016
Shower & Bathtub Forum & Blog Bathtub shoe drain too short Sep 15, 2016
Shower & Bathtub Forum & Blog Flexible PVC vs. fixed brass bathtub overflow/drain Aug 7, 2016
Shower & Bathtub Forum & Blog Stone bathtub drain help needed Jul 7, 2016
Shower & Bathtub Forum & Blog Bathtub drain conflict with truss top chord Jun 18, 2016
