Bathtub drain crisis!
Discussion in 'Shower & Bathtub Forum & Blog' started by miamicanes, Nov 24, 2009.
  1. miamicanes
    miamicanes New Member
    May 30, 2009
    Computer penetration tester & software engineer
    Pembroke Pines, FL
    Ack! My friend's here to help me install it, and I just realized that the drain includes a thick foam ring (for the overflow) and a thin rubber ring (for the drain). Do I still use plumber's putty, or do the rings take its place? The overflow foam goes behind the opening. The bottom drain ring appears to go between the upper side of the drain hole and the ring.
  2. Nate R
    Nate R Member
    Jan 11, 2007
    I perform R&D testiing at small engine manuf.
    Milwaukee, WI
    No putty on the foam overflow gasket. The rubber gasket goes underneath the tub, between the drain shoe and the tub. Plumber's putty will still go between the top part of the drain at the tub. (The silver part of the drain that is on the floor of the tub gets putty underneath it.)
Similar Threads: Bathtub drain
Shower & Bathtub Forum & Blog Delta Acrylic Bathtub Drain Sealant Tuesday at 11:03 AM
Shower & Bathtub Forum & Blog Bathtub Drain Tie-in - Help Needed! Jan 30, 2017
Shower & Bathtub Forum & Blog Drain Flange won't seal to bathtub Dec 21, 2016
Shower & Bathtub Forum & Blog Bathtub shoe drain too short Sep 15, 2016
Shower & Bathtub Forum & Blog Flexible PVC vs. fixed brass bathtub overflow/drain Aug 7, 2016
