Bathtub drain & cleanout plate
Discussion in 'Shower & Bathtub Forum & Blog' started by sdjerry, Sep 6, 2008.
  1. sdjerry
    sdjerry New Member
    Apr 18, 2008
    San Antonio, TX.
    This is basically two questions in one thread, so I'll get to it. I have attached a picture of the drain and the clean out plate in my bathtub. Basically I've only been able to take showers in this tub, never a bath. And that's because there's no sort of drain stopper with this, I've tried the cheap rubber stoppers but I can't find the right size and so water always gets through and it won't hold a bath. Is there any possible way I can replace this drain with a toe touch drain stopper myself? I'm thinking it's as simple as removing this old one and replacing it with a new one, but maybe I'm dreaming and it's best left to a plumber, you tell me.
    Also where a lot of baths have the lever for a drain stopper mine just has a clean out, and as you can see there is a clean out plate. The plate is old and unattractive, any way I can simply buy a replacement plate that looks newer and better and just replace it?
    Thanks for your help in advance. :)
  2. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    You may be able to find a toe tap or, lift and turn that threads right into the existing drain. It looks like that is what was originally there.
    Big box should had that and the overflow plate...
  4. sdjerry
    sdjerry New Member
    Apr 18, 2008
    San Antonio, TX.
    Thank you for responding Redwood.
    I don't see any visible threads inside this drain, so would a lift & turn style stopper still work with this somehow?
  5. Redwood
    Dec 15, 2007
    Service Plumber
  6. jimbo
    jimbo Plumber
    In the pic, I definitely see threads in the center of the crossbar X. Those threads will usually be either 5/16" or 3/8". Those are the two common sizes of lift&turn or push pull stoppers you will find.
  7. sdjerry
    sdjerry New Member
    Apr 18, 2008
    San Antonio, TX.
    Thank you for pointing out the threads in the center of the hole as I did not notice them. This should be a fairly simple task then.
    Regarding my clean out plate, forgive me if this sounds silly, but can that plate be opened without turning the water off? I mean if pop that thing open water isn't going to come gushing out of there will it? :)
  8. Redwood
    Dec 15, 2007
    Service Plumber
    Nope, open it up it is connected to the drain.
    If your tub was ever to clog that would be the access point.
  9. sdjerry
    sdjerry New Member
    Apr 18, 2008
    San Antonio, TX.
    Thanks Redwood & Jimbo, I feel like I can definitely get this done now.
Similar Threads: Bathtub drain
Shower & Bathtub Forum & Blog Delta Acrylic Bathtub Drain Sealant Feb 14, 2017
Shower & Bathtub Forum & Blog Bathtub Drain Tie-in - Help Needed! Jan 30, 2017
Shower & Bathtub Forum & Blog Drain Flange won't seal to bathtub Dec 21, 2016
Shower & Bathtub Forum & Blog Bathtub shoe drain too short Sep 15, 2016
Shower & Bathtub Forum & Blog Flexible PVC vs. fixed brass bathtub overflow/drain Aug 7, 2016
