Bathroom Tiling
Discussion in 'Remodel Forum & Blog' started by viennamicro, Jul 5, 2010.
  1. viennamicro
    viennamicro New Member
    Oct 31, 2006
    Executive Officer, 7th ID, USAAC, 11th ACR, ALMC,
    Vienna, WV
    Planning to tile my bathroom floor and walls.
    Very basic question, should I start with the floor or the walls?
  2. jadnashua
    Before even that, have you checked the floor structure to verify it is strong enough for tile? It's often easier to tile the floor then the walls because you don't have to be as neat with the tile cuts at the walls - the wall tile will cover those. Note, do not tile to the wall, leave a (small) gap and do NOT grout it. The tile needs some room to expand. If you want to avoid caulk at the joint there, makes some expansion joints designed for wall/floor transitions. Then, it doesn't matter which goes first, since each edge needs to be visible.
    Check out for tiling help.
  4. hj
    If the floor is not adequate for tile, do you even want to walk into the room? The weight of the tile is evenly distributed over the entire area, but YOUR weight is concentrated at your two feet.
  5. nukeman
    nukeman Nuclear Engineer
    Nov 20, 2009
    Nuclear Engineer
    The problem is not the weight of the tile, but the fact that tile doesn't like movement. If the floor is not solid enough, the deflection will cause the tile/grout to crack.
    I agree that the OP should check out (lots of good info on the subject and very helpful people).
Similar Threads: Bathroom Tiling
Remodel Forum & Blog Subfloor question for tiling a bathroom floor with heat mat under the tiles Sep 2, 2011
Remodel Forum & Blog Basement Bathroom Tiling Installation Questions Mar 6, 2010
Remodel Forum & Blog tiling floor in new bathroom May 10, 2007
Remodel Forum & Blog Tiling around bathroom light switches Mar 4, 2006
Remodel Forum & Blog Tiling over mosaic bathroom floor query Jul 13, 2005
