sirguynate
I just took apart my bathroom and am in the middle of a bathroom remodel. I removed my fiberglass shower and behind the shower was insulation behind a vapor barrier. My understanding that a vapor barrier behind a fiberglass shower is going to create a mold issue (vapor barrier behind vapor barrier.) However, I have an issue:
WA State Code:
502.1.6 Moisture Control:
502.1.6.1 Vapor Retarders: Vapor retarders shall be installed on the warm side (in winter) of insulation as specified in the following cases.
EXCEPTION: Vapor retarder installed with not more than 1/3 of the nominal R-value between it and the conditioned space.
502.1.6.6 Walls: Walls separating conditioned space from unconditioned space shall have a vapor retarder installed. Faced batt insulation shall be face stapled.
The wall behind my shower is an unconditioned space - attic. The insulation there along with the plastic vapor barrier had some mold on it. I do not have an option but to install faced insulation. I just have no idea what R rating i need.
I am in zone 5, but if someone could give me a hint on the appropriate R rating, or perhaps some other solution that would be appreciated.
I included a very rudimentary "drawing" of what I am dealing with. (there is plastic sheeting over the insulation)
https://ibb.co/zf2x4Kc
WA State Code:
