Bathroom exhaust make-up air and flow
Zayd
Michigan
Hello, everyone. As I continue my basement finishing project, I am planning my bathroom fan location and am hoping to get some simple guidance on how feasible my approach is from an air movement standpoint.
I originally planned to place the bathroom exhaust fan in a conventional location near the shower and toilet. Ceiling height concerns have me evaluating alternatives. Foremost, I don't want to do anything that compromises the purpose of the exhaust. At the same time, if I can achieve an effective exhaust arrangement while saving whatever ceiling height I can, that's the goal. To be clear, I am not installing the fan within the joist bays above, but rather below them due to other equipment in the bays and direction of exhaust.
Option 1 is to accept the lower ceiling and keep the original placement, relying on make-up air coming in from the door gaps:
Option 2 involves moving the fan near the door, reducing the door gaps down to a minimum, and installing a louvered opening in the wall of the bathroom that pulls make-up air from a conditioned adjacent storage room. My rationale is that this new opening would pull from the shower and toilet direction and help move humid/stinky air to the exhaust:
Is this a sensible solution? Or am I rolling the dice on this working?
John Gayewski
Iowa
Your plan should work if you have the makeup air hole large enough to favor that, rather than the door gap.
Suppose you put sheet metal across the bottom of one joist bay, and that joist bay, free of electrical stuff, would be a plenum?
Zayd
Michigan
Great idea except that the joists run perpendicular to the two fan locations. Believe me, I've run through just about every permutation of what is possible. 9" is a lot to lose!
Zayd
Michigan
The other complication I forgot to mention: I am mounting a Panasonic combination heater/fan, so the heat being close to the shower area is ideal. I am still willing to abandon this fan and remotely mount a fan with shallower ducting to the shower area, as suggested here. That leaves the heater portion to deal with, and perhaps an electric wall-mounted heater is the solution there.
