phillykitty
Hi there,
Hope someone out there can help me with this odd dilemma.
I am in the early stages of building a bathroom on the third floor of my house. There was no plumbing
up there before so I am starting with a blank slate.
My original plan was to have a walk-in shower but I have been convinced that I should have a tub/shower combo instead
for future resale value.
The waste lines are only partly roughed in. Supply lines haven't been done yet.
The dimensions of the room are approximately 6' x 10'.
In my original configuration I was planning on having a 5' x 3' walk in shower using a shower pan with an off-set
drain. In order to avoid running the drain line perpendicularly through 3 or 4 joists I had decided to have the shower head and hardware at
the opposite side of the drain. Since there is also a window at the drain end of the shower I won't be able to put the
shower head there anyway. I am planning on tiling the window figuring it will be far enough away from the shower to be problematic.
The long wall is plaster over brick so nowhere to hide plumbing inside the wall.
I can't move the shower/tub to the other end of the room as I am worried about structural issues and the other end of the room would put the weight of the tub close to the stairwell and there is already some sagging going on in that corner of the room--I live in a 100+ year-old brick row house.
I don't want to drop the ceiling in the room below the future bathroom in order to run the plumbing below the joists.
Ok so now if I want to put a tub in that same location and also avoid going through the joists then I will have to have
the tub filler at the opposite end from the shower head (using a Hansgrohe Raindance shower pipe with exposed thermostatic valve) but the tub filler will
be on the same side as the drain. And I am probably going to go with a Kohler 5' x 32" cast iron tub.
Am I crazy to even consider doing this? Will it look like total a** or just be a little unconventional?
The other problem with this configuration is that the only way to access the tub drain will be through the soffit in the room below.
Thanks in advance for any input. I hope my description is not too confusing.
