Basic faucet install
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by lotsoleaks, Mar 22, 2007.
  1. lotsoleaks
    lotsoleaks New Member
    Mar 22, 2007
    Ok, this should be easy. I've installed faucets before in my house but have always used the plastic water supply lines. This time I'm using the copper/chrome lines to a new faucet. It is leaking where the lines connect to the faucet, does there need to be something plastic or something between the two b/c it's metal on metal?? I've cranked it pretty tight and it still leaks.
  2. Verdeboy
    Verdeboy In the Trades
    Jun 12, 2006
    Get some flex supply lines, either nylon or braided metal. They won't leak.
  4. Cass
    Cass Plumber
    Nov 12, 2005
    Get the braded stainless steel supply lines and forget the plastic ones.
    Be sure you don't get the plastic braded stainless looking supply lines they sell at HD.
    That is quite the scam someone came up with. Sell plastic and make it look like stainless steel.
  5. lotsoleaks
    Mar 22, 2007
    Ok guys, that ain't very helpful. I don't want the plastic or braided b/c it's a pedestal sink and the lines will show. You see the chrome lines all over the place and they don't leak:confused:
  6. kordts
    kordts In the Trades
    Oct 15, 2005
    industrial service plumbing foreman
    exurban Chicago
    my advice is to remove the leaking speedy and redo it. Make sure you use a wrench and a holdback. Put a little dope or oil on the head of the speedy.
  7. jimbo
    jimbo Plumber
    If this is the one that, for lack of a better word, looks like a ball on top, those are metal to metal. Make sure it goes into the faucet shank straight.
  8. miranda12
    miranda12 New Member
    Aug 28, 2006
    Use some teflon tape?
  9. jadnashua
    NO TAPE. Tape is used to seal tapered threads...the ones in those connectors are not tapered. The threads apply pressure to the curved bits, and they make the seal. As noted, if it isn't inserted fully and square to the opening AND tightened enough, but not too much, it will seal just from the metal to metal joint.
  10. hj
    You will discover that you have to tighten that connecton as much as you can.
Similar Threads: Basic faucet
Plumbing Forum, Professional & DIY Advice Basic question here. leaky clawfoot tub faucet. Apr 6, 2013
Plumbing Forum, Professional & DIY Advice Basics....pulling a bath faucet help Dec 1, 2009
Plumbing Forum, Professional & DIY Advice Basic DWV Sketch Feb 20, 2016
Plumbing Forum, Professional & DIY Advice A few very basic disposal install questions: May 13, 2015
Plumbing Forum, Professional & DIY Advice Delta R10000 Valve - Basic Copper Piping System Design Nov 17, 2014
