J Blow
I'm working on a basement build - specifically a bedroom/closet right now. I'm using 12/2 wire with a 20 amp breaker and thinking I can do this all on one circuit. I'll end up with 8 outlets and 2 lights total.
My plan is to come from the box with a single wire and run through 7 outlets and then to a light from the 7th outlet. From the light I'll run to the last outlet and then finally to the other light. None of the outlets will be switched.
Can anyone see how this would be problematic using the 12/2 wire...or anything else? Thanks.
