brokenbricks
I have had some water damage in my finished basement so I had to gut just about everything. I have fixed the water issue and now am in the process of redoing it before my first child is born, so I am in a bit of a time crunch. The basement area that needs to be leveled is about 10 x 18 and is about 3" unlevel. I want to put down DriCore subfloor system but think I should probably level the floor first, and want to try and do it on my own. I see that DriCore sells a leveling kit so you can raise the panels to any height. I have also read about self leveling products but am stuck as to which is the easiest way to go as time is an issue. It is also framed all around so I am thinking that might come into an issue at some point and I am hoping I can leave the studs on the bottom in tact.
If anyone has any suggestions that would be great.
Thanks.
Thanks.
