Basement bathtub install
Discussion in 'Shower & Bathtub Forum & Blog' started by chukakid, May 15, 2009.
  1. chukakid
    chukakid New Member
    Jan 27, 2009
    retired
    colorado
    I'm helping with a basement finish and had the following question. Why does the overflow pipe from the tub go straight into the p-trap instead of the tub drain? Reason I ask, is we have rough-in problem with the location of the branch waste line which would go away if we went directly to the p-trap from the drain with a tee to the overflow. Any thoughts would be appreciated. :confused:
  2. Basement_Lurker
    Basement_Lurker One who lurks
    Jun 21, 2007
    I smash things and demand money.
    Victoria, BC
    There are two methods of installing a tub drain: a direct drain and an indirect drain method; the indirect drain is the most common method. The direct drain is the method you are hoping to use and it will work fine.
  4. hj
    drain
    1. The conventional connection gives a degree of latitude in the location of the "P" trap.
    2. To go directly to the drain requires a different style of drain fitting, called a "toe outlet waste", and it has to be EXACTLY in the correct position when the tub is installed.
    3. You cannot use a conventional overflow set up with a tee after the drain and then an elbow up to the overflow. At least not if you EVER intend to be able to snake it when the drain plugs.
Similar Threads: Basement bathtub
Shower & Bathtub Forum & Blog Bathtub install on basement slab - plastic below and on top of mortar? Sunday at 10:07 AM
Shower & Bathtub Forum & Blog How to cap off unvented bathtub/shower drain in basement May 14, 2013
Shower & Bathtub Forum & Blog Basement Bathtub, one piece, or cast with one piece surround, Brand preferences Nov 24, 2012
Shower & Bathtub Forum & Blog bathtub in basement question Oct 22, 2012
Shower & Bathtub Forum & Blog New basement bathtub question Nov 26, 2011
