Basement bathroom vent - is this right?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Hotbacon, Jun 8, 2011.
  1. Hotbacon
    Hotbacon New Member
    May 28, 2011
    Shillington, PA
    I have a 2" pipe coming out of our basement floor going up to the roof, which I assume is intended to be a wet vent for the basement lav/shower/water closet. I plan to cap the shower drain (we don't need another shower), and tie into the 2" pipe to install the lav. Can I just tie into the line with a wye and call it a day, or do I need another vent somewhere? See crude drawing located at:http://basementrefinishing.shutterfly.com/pictures/20. The red is the proposed new lav plumbing.
  2. Tom Sawyer
    Tom Sawyer In the Trades
    Nov 29, 2010
    Maine
    If your drawing is accurate and NOTHING dumps into that 2" pipe above the lav that you are going to install then yes, you are good to go.
  4. Hotbacon
    Hotbacon New Member
    May 28, 2011
    Shillington, PA
    Thanks for the reply Tom Sawyer.
    This 2" line is definitely a dry vent line right now. As a follow up question...is there a distance limit that my lav drain line must adhere to? Does it have to be a straight line (no 90* elbows)?
    I could put the vanity directly up against this vent line and tie into it, but I'm curious as to if I could put the vanity on another wall and run the drain line around the corner to the vent. I know I'd have to ensure it's sloped correctly the entire way, but are there any other restrictions?
Similar Threads: Basement bathroom
Plumbing Forum, Professional & DIY Advice New basement bathroom Jan 24, 2017
Plumbing Forum, Professional & DIY Advice Basement Bathroom Plumbing Jan 19, 2017
Plumbing Forum, Professional & DIY Advice Basement above floor Bathroom Dec 29, 2016
Plumbing Forum, Professional & DIY Advice Help with basement bathroom plumbing design Nov 16, 2016
Plumbing Forum, Professional & DIY Advice Need Help with Basement Bathroom Drain/Vent Nov 15, 2016
