Bad water pressure gauge
mikeandteri
Maryland
Hi, Water pressure gauge reads zero but pump seems to run alright. No obvious loss of pressure as pump does not kick on more than usual. Can pressure gauges go bad with no harm to the system? Will get it replaced but did not want to make an emergency drive to Home Depot in snow.
Valveman
Cary Austin
Lubbock, Texas
cyclestopvalves.com
The gauge is only for you to see. It has nothing to do with the workings of the system. My guess is that it doesn't read zero but rather has wrapped all the way around from freezing, and looks like zero again. The needle is probably on the other side of the stop post.
mikeandteri
Maryland
Thank you for the reply. No it reads just off zero on the correct side. Could it have gone bad or clogged with some sediment? We do have sediment in our well.
ditttohead
Water systems designer, R&D
Ontario California
Pressure gauges do wear out. Check out this video from WIKA, one of the best pressure gauge manufacturers. A little more expensive than most, but worth it!
[video=youtube;IxhNLtP8jpI]http://www.youtube.com/watch?v=IxhNLtP8jpI[/video]
