I have one of the water saver toilets that has 2 buttons to press. 1 will conserve water while 2 is a full flush. Installed this about 1.5 years ago. I've noticed lately (and it's getting worse) that when you flush... you hear the water go down then a good 5-7 delay of silence THEN you hear the bowl start to fill. I know this isn't "normal" behavior for this toilet as I notice it now and never did before ALSO I have 2 of the exact same toilets in other areas of the house that don't do this.
I am no pro at this stuff, I can probably fix / replace what is necessary just need help figuring out the culprit. Thanks!
