auger through the trap
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by plaza500, May 17, 2007.
  1. plaza500
    plaza500 DIY Member
    Nov 11, 2006
    Canada
    how the hell do i get an auger through the p trap???
  2. Verdeboy
    Verdeboy In the Trades
    Jun 12, 2006
    Snaking
    If the entire p-trap is glued, you will probably be limited to using a cannister snake, using a hose and bladder, or some sort of drain chemical. If the clog is further down in the drainpipe, you may need to run a much larger snake snake through a cleanout or vent.
    But wait for the pros to weigh in.
  4. plaza500
    plaza500 DIY Member
    Nov 11, 2006
    Canada
    i have a cannister snake, and its just bouncin; around in the overflow pipe, i can;t get it to make the bend at all!!!
  5. hj
    trap
    How old is the house. Some real old ones had a trap with a cleanout plug in the bottom and snakes will get caught in it and NEVER make the turn. Other cast iron traps have such a tight bend that the two legs are next to each other, and snakes will not make that bend either.
Similar Threads: auger through
Plumbing Forum, Professional & DIY Advice Unable to negotiate pipe bend with my auger. Keeps looping in the pipe. Jun 18, 2014
Plumbing Forum, Professional & DIY Advice Jet or Auger Aug 26, 2013
Plumbing Forum, Professional & DIY Advice Toilet issues... using a closet auger Aug 11, 2012
Plumbing Forum, Professional & DIY Advice Newbie help requested- bent snake/auger Feb 9, 2012
Plumbing Forum, Professional & DIY Advice I augered a cat out of a drain line Jun 8, 2009
