Attic Bathroom
Discussion in 'Remodel Forum & Blog' started by srcohen, Nov 24, 2008.
  1. srcohen
    srcohen New Member
    Nov 24, 2008
    I am renovating an existing attic bathroom with a tub. Part of the bathroom ceiling is the roof line. Should any insulation be placed between the roof rafters; and if, so what kind? Also, the manuals I've read said to staple 4 ml plastic to the beams before installing the cement board. Should this include the ceiling? Over the roof rafters?
    Thank you.
  2. jadnashua
    Depends on how the attic and roof are ventilated. If you have a ridge vent, then the channel must be maintained between the eaves and the ridge. They make foam panels for that, then you can put insulation over it.
    Tiling the ceiling is possible, but often not necessary. If you wish to do it, you need a vapor barrier behind the cbu. you don't want multiple ones, so you'd probably want to either use unfaced fiberglass, or faced that you slit to compromise it, then put plastic over it.
  4. frenchie
    frenchie Jack of all trades
    Dec 30, 2006
    Caretaker
    Not to answer your question, just bringing up a new one - is the bath original, or was it added? A tub full of water weighs a lot, and your ceiling joists might not be strong enough to take the load.
  5. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    Frenchie beat me with the question about the ceiling joists. I would urge you to have a serious heart to heart with the building inspector, an architect, or similar person to get sound advice with this. Water weighs something like 8 pounds per gallon, so a tub of water really puts a load on the floor/ceiling below it.
Similar Threads: Attic Bathroom
Remodel Forum & Blog Adding an attic bathroom Mar 18, 2012
Remodel Forum & Blog adding attic bathroom. cast iron stack questions Sep 22, 2008
Remodel Forum & Blog Adding Bathroom in Attic-Wet Vent? Mar 29, 2006
Remodel Forum & Blog Attic insulation. Sep 5, 2014
Remodel Forum & Blog Attic Insulation with a new roof Mar 11, 2014
