Attach SS Sink to new Granite Countertop
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by weneedhelp, Apr 12, 2011.
  1. weneedhelp
    weneedhelp New Member
    Jun 19, 2007
    AZ
    I have a 22/33 overmount that I have set into my 33" Sink Cabinet.
    Just had new granite top installed and would like to attach sink using a Adhesive as i had done in previous installation.
    What should I use?????? which will adhere to Stainless/Granite.
    Thanks, always appreciated.
    Sey
  2. hj
    silicone or tub/tile caulk will do it, although you may have to put a weight into the sink to hold it down until the caulk sets.
  4. jadnashua
    If the clips that come with the sink aren't long enough to clamp it to the slab, they generally also offer longer ones as an option. The caulk helps to keep crud from accumulating under the lip, water from leaking through, and to act as a second means of holding it in place (in addition to the clamps).
    Depending on the stone, some caulks can stain the stone. You may want to try it on a scrap or maybe the underside of the slab to see how yours reacts.
  5. weneedhelp
    Jun 19, 2007
    AZ
    i think i will just call in the morning.
    it gets caught at the bottom of the brass tube. 32298 grohe.
  6. weneedhelp
    Jun 19, 2007
    AZ
    fixed
    Fixed used a round file to clean instide of brass tube. thanks
    Sey
Similar Threads: Attach Sink
Plumbing Forum, Professional & DIY Advice Attaching sink to counter top Feb 17, 2016
Plumbing Forum, Professional & DIY Advice Gurgling after using bathroom sinks - venting question! (pic attached) Aug 19, 2014
Plumbing Forum, Professional & DIY Advice attaching kitchen sink with clamps to counter top Nov 4, 2012
Plumbing Forum, Professional & DIY Advice Temporary fix of a very small leak in a kitchen sink drain pipe attached to the jbend Jan 24, 2012
Plumbing Forum, Professional & DIY Advice How to reattach a drop-in sink? Oct 2, 2005
