Are these Concrete? How do I connect PVC?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by froddan, Jul 11, 2007.
  1. froddan
    froddan New Member
    Jun 14, 2007
    I have some roots in my sewer and need to replace a 10 foot section with PVC.
    The pipes are concrete (I think) sections, just short of 3 feet each about 5.5 - 6 " in diameter on the outside. They are connected into eachother because they are larger at one end (this is where the roots are growing).
    I have attached a couple of pictures.
    How do I connect PVC to these?
    Do I cut the concrete with a saw?
    Should I cut them in the thinner section and use a fernco coupling to PVC, or can I stick the PVC into it? I guess the inside diameter could be 4" then the latter wouldn't work...
    Thanks for any advice!
  2. Alectrician
    Alectrician DIY Senior Member
    Jun 15, 2007
    I recently cut mine with an angle grinder/diamond blade. It was difficult to manuver and a little tricky to get at the bottom. I am thinking that someone makes a stiff carbide sawzall blade that may work easier.
    Repair with the appropriate sized rubber coupling/stainless steel hoseclamp thingy. The OD of the 4" concrete pipe is much larger than that of the 4" PVC so the rubber coupling is flared out a bit. The make those couplings for several diferent types of pipe (clay for example) that are slightly different dimentions so measure accurately.
    Here's a tip and old plumber at a supply house passed on to me. Use a razor knife and cut the "stop" out of the center of the rubber coupling and it will slide all the way back on to your pvc, allowing the a tight fit piece to slip into place.
    Here's a tip from me. Put in cleanouts while you're at it.
  4. GrumpyPlumber
    GrumpyPlumber Licensed Grump
    Jun 18, 2007
    Plumber, self employed
    Licensed Grump
    Roll the rubber back after it's over the pvc side, then roll it back over the adjacent pipe once in place.
Similar Threads: Concrete connect
Plumbing Forum, Professional & DIY Advice Concrete Pipe 90 bend flush with basement floor. How to connect new pipe? Aug 21, 2012
Plumbing Forum, Professional & DIY Advice Quick check of toilet drain connection before I pour concrete? Jul 18, 2012
Plumbing Forum, Professional & DIY Advice Can PVC be encased horizontally in concrete Sep 6, 2016
Plumbing Forum, Professional & DIY Advice Best way to raise steel tub off concrete floor? Aug 28, 2016
Plumbing Forum, Professional & DIY Advice Sewer cleanout (and cover) in concrete Jul 31, 2016
