Any idea how to disconnect the sprayer hose from a Kohler Forte kitchen faucet?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by PC7060, Dec 17, 2013.
  1. PC7060
    PC7060 New Member
    Dec 9, 2013
    Northern VA
    Our relatively new (14 months)Kohler Forte kitchen faucet sprayer hose started leaking and we worked with Kohler to obtain a replacement. Unfortunately I cannot seem to remove the old hose from the brass coupler under the sink and the instruction that came with the hose are for the coupler type shown on the left of the picture below and mine is the unit on the right.
    The instructions online are for faucets built before 2009 so no help there.
    Any clues on how to remove? I've pressed / pulled on the white plastic ring but no luck. Plastic looks easy to break so I don't want to brute force it.
    This link lists the type of houses to be used for the Forte based on the build date of the unit.
    http://helptopics.us.kohler.com/ics/support/default.asp?deptID=5712&task=knowledge&questionId=806
    Thanks in advance.
    PC
  2. PC7060
    PC7060 New Member
    Dec 9, 2013
    Northern VA
    Answer - how to disconnect the sprayer hose from a Kohler Forte kitchen faucet
    Turns out that a combination of a vice grip and brute force is required to disconnect the hose.
    The white plastic section needs to be pressed up (hard!) toward the female brass receiver while pulling strongly on the brass male section of the hose. Given the size of the white locking piece, I couldn't get enough pressure with my hand alone and ended up using a pair of vice grips adjusted to slip around the outside of the host coupling while being small enough to press around the majority of the white 3/4" round plastic ring (see pic of hose and vice-grip below, faucet not shown).
    Once you get the pliers adjusted, push on the vice grips and pull like hell on the hose. Then, if you are lucky, the hose pops out and dumps a cup of water in your face.
    The old hose couple had corroded just enough to bond to the mating section which is where the brute force component of the job comes in.
  4. hj
    I use a Crescent wrench around the hose/pipe to push the rings in.
Similar Threads: idea disconnect
Plumbing Forum, Professional & DIY Advice Idea: Sewer leak detecting dog Apr 13, 2016
Plumbing Forum, Professional & DIY Advice Plumbers: Any Ideas on what this is? Feb 12, 2016
Plumbing Forum, Professional & DIY Advice Whose dumb idea was it to bring water into our houses anyway? Jul 1, 2015
Plumbing Forum, Professional & DIY Advice Arm mounted diverter, bad idea? Jun 17, 2015
Plumbing Forum, Professional & DIY Advice Weird water pressure issue in house... tenants moving in today, any ideas? (w/pics) Aug 18, 2014
