Any hope of getting well water in clay soil?
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by bigsmile, Nov 29, 2010.
  1. bigsmile
    bigsmile New Member
    Nov 29, 2010
    Mississippi
    I just dig a shallow well down to a little over 15'. I hit water at close to 15 feet. I think I can dig 10' more without problem. But what concerns me is that the soil seems to be mostly really fine clay. Actually, when I dug down to 15' or so, I didn't even know that I hit water. I took a long rest and when I came back, I found water.
    So, is it still realistic to expect, say, 1 gpm or even a quart per minute from this well (when it's dug down to about 25')?
    By the way, the hole I dug is 6 ID.
  2. Thatguy
    Thatguy Homeowner
    Aug 27, 2008
    A bounty hunter like in "Raising Arizona"
    MD
    Does this help?
    http://groundwater.ucdavis.edu/Publications/Harter_FWQFS_8086.pdf
    Here's a test you can run
    Well diameter= 0.5 foot
    Water depth= 15 feet
    Well water volume [V]= 22 gallons
    Well input/output [IO]= 1 GPM
    user demand [D, D>IO]= 2 GPM
    output duration [OD] = V/(D-IO)
    OD= 22 minutes
    output gallons [G] = OD x D
    G= 44 gallons
  4. valveman
    Mar 15, 2006
    Pump Controls Technician
    Lubbock, Texas
    Fill the hole with water from another source. If it won't take water, it won't make water.
Similar Threads: hope getting
Pumps and Tanks Well Forum & Blog. Water is life. Hopefully last dumb question, Aug 22, 2013
Pumps and Tanks Well Forum & Blog. Water is life. Final (Hopefully) installation pictures of cross, control valve, pressure tank, pump Nov 16, 2012
Pumps and Tanks Well Forum & Blog. Water is life. Well Pump Controller/Pressure Switch Problem...I hope Nov 17, 2008
Pumps and Tanks Well Forum & Blog. Water is life. Am I getting ripped off on a submersible pump? Jan 25, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Old style well not pressurizing, trouble getting water Jan 3, 2017
