Jeff Davis
I like that and not in a joking way throw a jim cap or duct tape it, and see the differance. I double check my theorys keeping an open mind . what I run into all the time is poor workmanship worn out products and some people need it working not always interested in fixing everything thats wrong and rebuilding thier entire house . Some times gotta decide what gives the most bang for the buck.
Jeff Davis let us know how you proceed
Good suggestion, Jeff Young. I'll put some duct tape over the pipe (or create a clog) this evening and see if that affects the 2 bathrooms down the line from the hole.
Depending on how that goes, I'm either going to put in a cleanout tee or a frenco coupler—those parts should arrive tomorrow. Since I've never done such a fix before and accessing the pipe is extremely hard, I figured I'd leave myself both options. Once the part of choice is installed, I'll scrub away the mold with soap and water then I'll spray the affected areas with a sodium hypochlorite, water, and surfactant solution to be sure that the mold won't come back. After that, I'll replace the two rotted cardboard insulation stops; I'll likely make my own out of carboard boxes, since it seems you can only buy insulation stops in quantities of 50 or more.
