Air in pipes
Discussion in 'Pumps and Tanks Well Forum & Blog' started by seaeddy, Oct 29, 2007.
  1. seaeddy
    seaeddy New Member
    Oct 15, 2005
    Periodically, when the faucet is turned on I get short blasts of air for a minute or so, and than water running normally. I have a shallow well, 25', jet pump, and a bladder cold water tank. What's going on?
  2. speedbump
    speedbump New Member
    Jul 15, 2005
    Water well and pump tech.
    Riverview, Fl.
    You must have an air leak somewhere. If your well screen is getting plugged making the pump pull more vacuum, this minor air leak can get worse.
    bob...
Similar Threads: pipes
Pumps and Tanks Well Forum & Blog Hot water from cold water pipes Jun 27, 2016
Pumps and Tanks Well Forum & Blog Pressure switch and freezing pipes Jun 13, 2016
Pumps and Tanks Well Forum & Blog New wider pipes, lower water pressure Sep 26, 2014
Pumps and Tanks Well Forum & Blog Shallow well won't prime after pipes are replaced. Apr 9, 2013
Pumps and Tanks Well Forum & Blog Replaced shallow well pipes and put in pitless adapter: Now no water pumped Jul 26, 2012
