Advice on running new main drain pipe in basement
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by clifforddog1, Feb 20, 2007.
  1. clifforddog1
    clifforddog1 New Member
    Feb 20, 2007
    Canada
    Hello all,
    Our main waste pipe inside the house (old cast iron) is broken in several places and needs to be replaced.
    I'm going to break up the floor and take out the old pipe (I'm in construction) and replace it with 4" PVC.
    Just thought I'd see if anyone has any tips for me in this venture, as I mentioned I'm in construction and work as a stone mason so I can break up the floor alright.
    I need to replace everywhere inside the house to the clean out in the garage. (about 30 linear feet)
    I have a few questions:
    1. Is 1/4 inch drop per inch okay for drainage?
    2. When I come to existing pipe I want to salvage or join into is there a special trick to not breaking pipe your wanting to join into? (bad wording I know)
    3. Any other tips you have appreciated.
    Thanks,
    John
  2. jadnashua
    1/4"/foot is fine - more is okay, too.
    removing CI from a leaded connection is a pain (I've only done it a couple of times, so I'm no expert). Connecting the PVC to the CI hub is fairly easy, if you can find the right Fernco doughnut. CI apparantly is made in three sizes - normal, HD, and who knows. I had one "normal" and one who knows in my endeavor. The HD doughnut was still about 1/4" too small. The "normal" one fit in well. Basically, it is a rubber doughnut and a (tight) press fit into the hub.
    If the pipe is fine near the hub, use a snap cutter leaving a stub and use a no hub connector - much easier than trying to remove the pipe from the leaded connection.
    I'd excavate enough to allow you to use the snap cutter to break it into small enough sections you can more easily manage. If it is really swiss cheese, you might end up crushing it, but that is okay too.
Similar Threads: Advice running
Plumbing Forum, Professional & DIY Advice Advice on stack and main line Feb 13, 2017
Plumbing Forum, Professional & DIY Advice Bathroom planning advice (venting questions primarily) Feb 12, 2017
Plumbing Forum, Professional & DIY Advice Advice on bathroom sink drain Jan 22, 2017
Plumbing Forum, Professional & DIY Advice Polypropylene for Drain/Waste/Vent Installation Advice? Jan 4, 2017
Plumbing Forum, Professional & DIY Advice I've got some sink drainage issues; need advice/diagram to correct Jan 3, 2017
