adjusting home water pressure
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by 515421, Jan 16, 2008.
  1. 515421
    515421 New Member
    Dec 23, 2007
    I Have A 2hp Sta Rite Vertical Water Well Jet Pump Well Is About 70 Ft Deep I Have Low Water Pressure In The Home All The Time. It Gets Better When The Pump Cuts On And Fills Up But When The Tank Nears Empty The Pressure Gets Really Low Until It Comes On. How Do You Adjust The Home Pressure On That Pump Is It By The Regulator And If So, Is It Higher The Number Higher The Pressure?
  2. Gary Slusser
    Retired
    It sounds as if you need to check and adjust the air pressure in your pressure tank but...
    What does the pressure gauge say the pressure range is; I.E. 30/50 or 40/60 etc.?
    If you don't have a gauge, you do need one.
    You may have a valve that isn't open fully or a loose washer in a stop valve or some other partial blockage restricting the water flow.
    And it would help if you wouldn't capitalize every word.
Similar Threads: adjusting home
Pumps and Tanks Well Forum & Blog. Water is life. Adjusting AVC in pneumatic tank Feb 19, 2015
Pumps and Tanks Well Forum & Blog. Water is life. Adjusting Pressure Switch - Only one adjustment nut.. Mar 28, 2009
Pumps and Tanks Well Forum & Blog. Water is life. URGENT: I have 2 ?'s about adjusting a 40/60 pressure switch Jun 25, 2008
Pumps and Tanks Well Forum & Blog. Water is life. adjusting new pressure switch? May 27, 2007
Pumps and Tanks Well Forum & Blog. Water is life. adjusting pressure switch Feb 18, 2007
