Adjust Temperature on a Delta Hot Tub Faucet 1400 Series
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by nateham, Apr 11, 2009.
  1. nateham
    nateham New Member
    Apr 11, 2009
    What do I need to do to adjust the water temperature on this type of hot tub faucet? Right now, the temperature is lukewarm and I need it to be warmer.
    Please help.
    Nate
  2. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
  4. jadnashua
    Basically, all new shower valves have a temperature limiting adjustment...it could be a screw, or a bracket or something. It's usually fairly easy to figure out once you get the eschuthion off. the hassle with these is that for safety, between winter and summer, the incoming cold water can vary quite a bit, and if adjusted in the winter, you could get it too hot in the summer and scald a young or old person (whose skin is thinner). that's one reason why I prefer a thermostatically controlled valve over a (minimum requirements) pressure balance and limit stop version.
Similar Threads: Adjust Temperature
Plumbing Forum, Professional & DIY Advice How to adjust regulator Dec 24, 2016
Plumbing Forum, Professional & DIY Advice Adjust hot/cold on single handle Moen bathtub control? Nov 2, 2016
Plumbing Forum, Professional & DIY Advice Adjusting Shower/Tub Valve Sep 27, 2016
Plumbing Forum, Professional & DIY Advice Low ceiling, p-trap and drain run adjustments feasible? Sep 3, 2016
Plumbing Forum, Professional & DIY Advice Pump wouldn't shut off so had to adjust switch ...help... Feb 28, 2016
