Pro Flo tub delta faucet handle
Tabermr
Amarillo Texas
I recently purchased a new home. Discovered that the cold water handle on the delta faucet is a bit loose. The tub is free standing. The faucet and handles are deck mounted. How do obtain access to tighten the loose cold water handle? I don’t see any way to tighten the handle. Thanks in advance for your help.
Neil Binda
Toronto
Under the boy and cold indices should be a Phillips screw. Use a sharp knife and gently pop them off or screw them off from there you should see a Phillips screw where you tighten it back .
Tabermr
Amarillo Texas
Thank you. I will try that, although I’d previously looked for a cap that would pry off and didn’t see one. I will look again.
