Adding fitting to existing drain
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by chukakid, Feb 24, 2009.
  1. chukakid
    chukakid New Member
    Jan 27, 2009
    retired
    colorado
    Okay, you probably have answered this a million times but I couldn't locate what I needed to know so here goes. I'm going to finish my daughters basement and have run into a little problem. She wants a bar sink which unfortunately is not going to be on the same way as the bathroom so I have a problem with the waste line from the sink. There is a drain line from the kitchen sink that is close that I would like to tie into. The pipe is white PVC with a clean out just above the basement floor level. So I think I can add a 3x3x1 1/2 combo tee - wye as long as I get the drain line from the sink high enough. My question is how to I cut into an existing drain line and add a the new tee? I really don't want to redo the whole drain line. thanks:confused:
  2. nhmaster
    nhmaster Master Plumber
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    slip couplings, fernco's take your pick. Make sure you vent it.
    [​IMG]
  4. hj
    drain
    Back up a bit. Your SECOND problem is making the connection. Your FIRST one is that you cannot just connect to that pipe without making some provisions for venting, which you have not even considered.
  5. chukakid
    chukakid New Member
    Jan 27, 2009
    retired
    colorado
    Adding to existing drain.
    Sorry should have included that fact. The house and the basement rough use the AAV valves for venting so I will tee off the sink drain with a new valve. Also, any recomendations on the heigth of the sink drain after the p-trap?
  6. hj
    Aav
    An AAV will NOT work properly in this situation because it is a negative pressure vent, and your sink will be subjected to POSITIVE pressures which an AAV cannot handle.
  7. chukakid
    chukakid New Member
    Jan 27, 2009
    retired
    colorado
    Oh oh, I was afraid of that. So since this sink is in the basement how could I vent it? I cant' get thru the upper floor.
  8. jadnashua
    While you don't have to run a new line all the way to the roof, you do need to make the connection 6" above the flood plane of the highest drain served by the vent.
Similar Threads: Adding fitting
Plumbing Forum, Professional & DIY Advice Venting madness: Adding a second washer, moving one. Thursday at 7:43 PM
Plumbing Forum, Professional & DIY Advice Adding Softener Drain to Main Drain Tuesday at 7:37 AM
Plumbing Forum, Professional & DIY Advice Option for adding to my soil stack for second toilet. Feb 10, 2017
Plumbing Forum, Professional & DIY Advice Adding basement kitchen DWV question Feb 3, 2017
Plumbing Forum, Professional & DIY Advice Adding standpipe to existing sink Feb 1, 2017
