Access Panel for Tub
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Ryan1978, Mar 5, 2009.
  1. Ryan1978
    Ryan1978 New Member
    Oct 22, 2007
    Another day, another challenge:)
    I have a question about my access panel for the tub.
    As you can see from the drawing, I can't do a 12" x 18" access panel straight in from the back. I have to come in from an angle.
    My question is, does the actual opening have to be 18" wide to get the motor out if necessary, or is that to allow someone enough room to reach in there to work?
    Another consideration is that I'll have to cross over the drain pipes. I did make the opening about 15" tall, so I might have a little leeway to go over the pipes if necessary.
Similar Threads: Access Panel
Plumbing Forum, Professional & DIY Advice Access Panel vs Drywalling Jun 1, 2015
Plumbing Forum, Professional & DIY Advice Access panel required? Jun 19, 2011
Plumbing Forum, Professional & DIY Advice Access Panels Oct 12, 2010
Plumbing Forum, Professional & DIY Advice Threaded Connections and No Access Panel May 7, 2010
Plumbing Forum, Professional & DIY Advice How important is access panels...... Apr 19, 2010
