A toilet with tank to fit in a 26" space? And, it must flush well!
Discussion in 'Toilet Forum discussions' started by Absoluterob, Jan 25, 2008.
  1. Absoluterob
    Absoluterob New Member
    Jan 25, 2008
    HI everyone,
    I'm renovating my bathroom and currently have a commercial toilet with a flushometer. It's there due to space reason. The model I have is the only one that would fit in the space. Now that I'm renovating, I'd like a toilet with a tank. Unfortunately, the space requirements remain the same. It must fit into a 26" space. A toilet that is larger will prevent the door of the bathroom from opening and closing.
    The Toto Drake is close but just a tad too large. Any other suggestions? And, yes, it must flush well enough to suck down a bowling ball!
    Thanks,
    Robert
  2. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    Even if you find a toilet that fits as you want, there is still going to be a space problem with the door. I was faced with a similar problem years ago when I remodeled my bathroom and went with a pocket door. I like it so well that when I added a small bathroom in my basement, I did the same thing. You might want to consider this as an option. It certainly would allow you to use whatever toilet you want to use.
  4. Absoluterob
    Jan 25, 2008
    Gary,
    I thought about it but circumstances do not allow. There is a radiator on one side of the door that cannot be moved and pipes in the wall on the other side of the door. Thanks for the suggestion, though! (A folding door or a sliding door of some kind are out of the question, too. They break too easily.)
    My best,
    Robert
  5. jadnashua
    Depending on where the supply lines for the radiator go, having that on one side doesn't preclude installation of a pocket door as long as you can open up the wall on one side (it doesn't have to be in the bathroom), and there are no wires, ducts, or pipes that can't be moved - a pocket door can be installed.
    I also put one in my bathroom, and it really helps. It's sort of a weird setup and actually has two doors into the room that both swung in. Still have one swinging door, but the other is now a pocket door.
  6. Dunbar Plumbing
    Dunbar Plumbing Master Plumber
    Apr 18, 2005
    Service Plumber, Outdoor Temperature Relief Owner
    Toilets require a minimum 15" from center of toilet to wall or permanently affixed fixture to be code compliant.
  7. hj
    toilets
    A round front toilet is typically 25" from front to back of the tank, BUT the installed dimension to the front of the bowl depends on where the opening is in the floor. If it is at 11 1/2", for example, the bowl will sit back an 1 1/2" from where it would be if the pipe is 13" from the wall.
  8. Absoluterob
    Jan 25, 2008
    Hi everyone,
    A quick thank you for the advice! Fortunately, a Toto Ultramax round bowl fit and the door just squeaks by it.
    My best,
    Robert
Similar Threads: toilet tank
Toilet Forum discussions Is it correct 1.28 GPF is not determined by the toilet bowl but tank? Feb 14, 2017
Toilet Forum discussions Need Norris Toilet Tank Repair or replacement Feb 11, 2017
Toilet Forum discussions Alternate Tank Lid for Toto Drake 1.6gpm Toilet Dec 31, 2016
Toilet Forum discussions I have a Kohler wall mount toilet with a Geberit wall mount tank/ carrier Dec 13, 2016
Toilet Forum discussions four bolt toilet tank Dec 13, 2016
