A new rough-in valve thats deeper than the old
Discussion in 'Shower & Bathtub Forum & Blog' started by rrgtmb, Feb 26, 2013.
  1. rrgtmb
    rrgtmb New Member
    Feb 26, 2013
    NJ
    I purchased a new kohler k-304 rough-in valve that has the water supply inlets deeper (when installed to the correct depth) than my existing valve. Is there an easier way to install this or do I have to move all this copper pipe back?
  2. kreemoweet
    kreemoweet Member
    Sep 7, 2009
    Seattle. WA
    Furr the wall out? It's exceedingly rare to be able to change out a shower valve without also reworking the supply piping.
  4. hj
    IT depends on HOW much deeper it has to be. There is some latitude in the "proper depth" dimension so you have to do some homework to determine whether the trim will fit at the shallower dimension. IF not they you either have to move the pipes or the finished wall surface. From the picture, it appears that revising the water lines to accommodate the new valve would be quite easy. You should not even have to do anything to the two riser pipes.
Similar Threads: rough-in valve
Shower & Bathtub Forum & Blog Low water flow to a shower head can be caused by a low-flow rough-in valve/cartridge Apr 9, 2016
Shower & Bathtub Forum & Blog Grohe 35015000 Universal Pressure Balance Rough-In valve Feb 10, 2015
Shower & Bathtub Forum & Blog Stud interferes with new rough-in valve placement Dec 5, 2013
Shower & Bathtub Forum & Blog Delta Rough-In Valve for shower-only install Oct 21, 2013
Shower & Bathtub Forum & Blog Delta Faucet R10000-PX Universal MultiChoice Universal Rough-In Valve Dec 17, 2012
