A few misc questions
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by traveling man, Jan 6, 2007.
  1. traveling man
    traveling man New Member
    Jun 20, 2006
    It's time to change the diaphram water tank. Does a larger capacity tank mean that the pump will not have to come on as often? I have a 20/40 pressure switch at present. The tank comes with 30 lbs of pressure installed. Do I have to let out 10 lbs to match my switch? Will a 40/60 switch result in more water pressure? Is there anything special I need to know about installing a new tank?
    Thanks much to this forum. I have learned quite a bit about my water well system.
    Traveling Man
  2. speedbump
    speedbump New Member
    Jul 15, 2005
    Water well and pump tech.
    Riverview, Fl.
    It's time to change the diaphram water tank. Does a larger capacity tank mean that the pump will not have to come on as often? Yes it does, or get a Cycle Stop Valve
    I have a 20/40 pressure switch at present. The tank comes with 30 lbs of pressure installed. Do I have to let out 10 lbs to match my switch? Let out 12 pounds to make the pressure in the tank 18 lbs.
    Will a 40/60 switch result in more water pressure? Yes, but air the tank up to 38 lbs.
    Is there anything special I need to know about installing a new tank? Should be a direct replacement all but the air pressure.
    bob...
  4. traveling man
    Jun 20, 2006
    Thanks Bob for the quick response. You are always very informed.
    Traveling Man
Similar Threads: misc questions
Pumps and Tanks Well Forum & Blog. Water is life. Newb questions about water storage Tuesday at 6:26 AM
Pumps and Tanks Well Forum & Blog. Water is life. Reset switch questions Jan 4, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Water System and Cistern Questions Dec 10, 2016
Pumps and Tanks Well Forum & Blog. Water is life. DIY Water Well Questions Aug 29, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Newbie with questions... Lift pump for municipal water supply Aug 14, 2016
