30A Fusible Disconnect Switch w/ Copper Pipe used as fuses
Discussion in 'Electrical Forum discussion & Blog' started by edstevn, Nov 3, 2008.
  1. edstevn
    edstevn New Member
    Oct 27, 2008
    I found a General Electric 30A/240V single phase fusible disconnect switch that was used as a local service disconnect for a hot water heater. It was fed from a 30A/2P breaker out of a nearby breaker panel. I noticed it had (2) 1/2" pieces of copper pipe installed in place of fuses. I'm sure the National Electric Code book would site this as a code violation. Would they accept dummy fuses ? Do you replace the copper pipe with fuses or replace the switch with a non-fusible type?
  2. jimbo
    jimbo Plumber
    San Diego, CA
    I don't know if there is such a thing as a dummy fuse. I think it is called "copper pipe"!!
    You can most likely use a non-fused disconnect, but I don't see how it would ever be legal to bypass what is intended to be a fuse.
  4. hj
    non fuse
    There have been people here who flatten a copper tube and then put it in the meter socket, after it was pulled for nonpayment of the bill, but I am sure the utility does not consider it a "dummy meter".
  5. Chris75
    Chris75 Electrician
    Aug 12, 2007
    Electrician
    Litchfield, CT
    Either replace with fuses or dummy fuses, but get rid of the copper pipe.
  6. Thatguy
    Thatguy Homeowner
    Aug 27, 2008
    A bounty hunter like in "Raising Arizona"
    MD
    The current to melt a piece of pipe like this was figured out on another forum. The connecting wires and everything else will melt before this does. I guess that makes it an "anti-fuse."
  7. Alectrician
    Alectrician DIY Senior Member
    Jun 15, 2007
    At least they used copper.
    [​IMG]
  8. Johnny C
    Johnny C Electrician
    Oct 19, 2008
    Elect Teacher, Consultant, Seminar Presenter, Elec
    Mass. & now Virginia Beach, VA
    30 A fusible disconnect with CU pipe.
    Installing copper pipe in place of proper fuses or fuse blanks is a Code violation of 110-3(B). Use of the disconnect sw with other than a product for which it was tested and listed by the testing laboratory. I will not say I haven't done this in an emergency, but it is a Code violation even though the circuit breaker ahead of the disconnect is rated for the circuit size.
  9. Thatguy
    Thatguy Homeowner
    Aug 27, 2008
    MD
    And if you want to make it into a slow blow fuse, fill the pipe with water before crimping. That way the water has to boil off before the pipe melts.
    All-in-all this is a very versatile circuit element.
    Just kidding.
  10. hj
    fuse
    If the tubing is sealed so the water cannot leak out, neither will the steam. So the water will heat to a "superheated" condition, (not steam), until something ruptures and then there will be a 'mini' explosion as the energy is disipated in a matter of microseconds. It probably "looked" like copper when it was installed, but now it looks "silver" probably from being overloaded a few times.
  11. jar546
    jar546 In the Trades
    Feb 20, 2008
    USA
    Violation NEC 2005 reference standard
    110.3(B)
    110.9
    110.10
    210.20(C)
    240.6(A)
    240.10
    240.60(C)
    240.61
    Take your pick. Remove and replace with the proper sized fuses
  12. edstevn
    edstevn New Member
    Oct 27, 2008
    Thanks for your help!
  13. Thatguy
    Thatguy Homeowner
    Aug 27, 2008
    MD
    So should I lay off all the employees I have already hired to start building these little gems?
    :p
  14. Paul Matejcek
    Paul Matejcek New Member
    Apr 1, 2016
    Wisconsin
    There are dummy fuses. A person might use one in a 110 v single phase circuit passing through a fused disconnect, no?
  15. hj
    A "fused disconnect" with "dummy fuses", is a DISCONNECT only, and UNLESS it is fed from a fused circuit it is not only illegal but completely unsafe.
  16. WorthFlorida
    WorthFlorida USCG escorting cruise ship leaving Port Everglades
    Oct 28, 2009
    Retired
    Orlando, Florida
    A dummy fuse is the dummies right finger on the right blade, left finger on the left blade without a pipe.
  17. hj
    Do you wet your fingers before touching the blades?
  18. DonL
    DonL Jack of all trades Master of one
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    That does not look like any copper that I have seen.
  19. hj
    It WAS "golden" before it was overheated, maybe red hot, by overloads many times. Notice the blades are also no longer golden. Remember, in spite of what the title says, that is NOT a "30 amp disconnect", it is something like a 1,000 amp disconnect.
Similar Threads: Fusible Disconnect
Electrical Forum discussion & Blog Shopvac dead - fusible link? Aug 1, 2013
Electrical Forum discussion & Blog Distance From Meter to Disconnect Jun 26, 2014
Electrical Forum discussion & Blog Heat pump service disconnect Jan 28, 2013
Electrical Forum discussion & Blog Building Service Disconnect question Jan 21, 2012
Electrical Forum discussion & Blog how do i disconnect power on a split buss? Jan 5, 2012
