2" sewage check valve recommendation
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Hotbacon, Dec 19, 2013.
  1. Hotbacon
    Hotbacon New Member
    May 28, 2011
    Shillington, PA
    I need to replace the check valve above our sewage ejector pump again (2nd time in 10 years). The first time the flapper had broken loose, thus defeating the purpose of the check valve. This time I'm just tired of hearing the loud banging and worrying what it's doing to the system. Can anyone recommend a good quality 2" sewage check valve? Slip on style is preferred to solvent weld.
    I googled silent sewage check valve, as is often recommended in similar threads, but am not sure which brands are good quality.
  2. Tom Sawyer
    Tom Sawyer In the Trades
    Nov 29, 2010
    Maine
    Replace it with what you can find locally and this time drill a 3/8" hole through the check before installing it.
  4. hj
    quote; this time drill a 3/8" hole through the check before installing it.
    And, if you do that, you might as well remove the check valve because it will be useless.
  5. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    It's a little pricey, but we have grown to love the A.Y. McDonald 2066s.
  6. Tom Sawyer
    Nov 29, 2010
    Maine
    Yep, thought he was talking sump pump
Similar Threads: sewage check
Plumbing Forum, Professional & DIY Advice Sewage sump failures and check valves Mar 5, 2014
Plumbing Forum, Professional & DIY Advice Question on 2" sewage check valve Jan 21, 2012
Plumbing Forum, Professional & DIY Advice New Campbell Mfg 2" Silent Sewage Check Valve slow to open Nov 30, 2011
Plumbing Forum, Professional & DIY Advice How to drain the vertical 2" PVC sewage pipe above check valve? Sep 11, 2011
Plumbing Forum, Professional & DIY Advice Sewage Check valve - combating the city's sewer system Aug 28, 2011
