2" drain lines and 1/2" supply lines in a 2x4 wall
Discussion in 'Remodel Forum & Blog' started by aroccos, Sep 24, 2006.
  1. aroccos
    aroccos New Member
    Sep 24, 2006
    I am having trouble squeezing everything in!!
    I ran the drain lines horizontally and now I am
    running the supply lines. There is enough room
    if the supply lines are allowed to touch the drain lines.
    Is this ok? The supply lines would be right up against
    the drywall (behind the cabinets so I am not worried
    about someone nailing through them.
    Alexis
  2. Verdeboy
    Verdeboy In the Trades
    Jun 12, 2006
    If the supply lines are right up against the drywall, the condensation on them will eventually rot out the drywall.
    Can you post a photo?
  4. hj
    condensation?
    There is no condensation inside the walls because there is no mumidity there.
  5. aroccos
    aroccos New Member
    Sep 24, 2006
    insulation
    What if I wrap the supply lines with 1/8" foam/foil insulation?
    Will it pass inspection?
    Alexis
  6. Verdeboy
    Jun 12, 2006
    I don't think I've ever seen copper pipes that were actually brushing up against the wall, which is my concern. Even if no humidity, it seems a bit odd and might result in noisy pipes.
    I don't know what the codes are. I'm sure others on this forum might know.
  7. OldPete
    OldPete DIY Senior Member
    Jan 4, 2006
    NJ
    I was under the impression that if the temperature inside the wall cavity and the temperature of the water inside the pipes is greatly different (which happens often) then you can get condensation on the pipe.
    I might have missed something.
  8. jadnashua
    There is normally very little air movement within a wall, especially if it is built properly. Without air movement, there is a finite amount of moisture. It normally isn't a problem. Now, an open pipe in the basement ceiling, open to the air can drip a bunch.
Similar Threads: drain lines
Remodel Forum & Blog Bathroom Remodel - Toilet Drain Lines Aug 9, 2005
Remodel Forum & Blog Block off main drain lines in basement Feb 25, 2005
Remodel Forum & Blog What Is This Pipe ? AC condensate drain connection Sep 21, 2015
Remodel Forum & Blog Joist in the way of new shower drain Apr 1, 2015
Remodel Forum & Blog Basement floor & wall insulation with perimeter drain Jan 21, 2015
