11.5" rough in after wall tile...arrrgh
shawn clark
Edmonds, Washington
REmodeling basement and ended up with only 11.5" rough in after tile setter built out the wall almost an inch. I need a recommendation on a toilet that will have enough clearance to accommodate this oversight.
I like everything about the Aquia style toilet..tall, slender & sleek looking, skirted, and id like dual flush if possible. Im not sure on height yet, but Ive never been unsatisfied with the old standards Ive been using. Actually, the Aqui(II or III?) was the one I almost purchased but didnt for 2 reasons...1 is the rough in problem described above, and 2nd is that I read several reviews indicating the Aquias have issues clearing and cleaning the bowl and needs to be cleaned manually after every dropped load...or it has to be right on target or something of that nature. Im a single dad with 2 teenage girls, and Im not sure my girls would take me too seriously if I had to put them through "Leaving a Dump w/o a trace - 101" course. So, just wondering if this is maybe an older model these folks commented on, is it accurate?
Anyway...if anyone could help me with a recommendation I would appreciate it.
Cheers
Gary Swart
Yakima, WA
Most toilets when installed on a rough-in that is exactly to specs will have quite a bit of space between the tank and the wall. I can't speak for all of toilets, but I have a Toto Drake, and a Toto Dartmouth each of which is installed on exactly 12" rough-ins and there is a couple of inches behind them. 1/2" is not that big of a deal at least in most cases. You can sometimes fudge the flange bolts a quarter of an inch if necessary.
https://terrylove.com/forums/index....ion-instructions-written-by-jamie-love.12606/
WJcandee
Wise One
New York, NY
Like Gary said. Most Toto's leave about 3/4" behind the tank on a 12" rough in. (There are a couple that use the whole space, but they are prominently-labelled as such, because it's unusual.) The Aquia 2-piece (CST416M) spec sheet shows 1/2" from the back of the toilet to the wall, so if it is truly 11.5" from the finished wall to the centerline of the closet flange, the Aquia should still just fit, but it might be tight because of differences in casting the toilet. There are ways to "cheat" the toilet adapter (or toilet) a bit forward on the flange, because the outflow hole is only 2.125, and the flange is at least 3", so you get 3/8" or so that you can slide it forward and still have it dump into the hole in the floor. But this can be a bit tricky so come back for more info if you have a problem. Careful about whether you have any molding around the base though, because that will start to be a problem with the Aquia.
The CST 412MF (which is the Universal Height version of the 416M) spec sheet now shows 3/4" from tank to wall, so that should fit, although again there may be some variances in casting.
The Aquia 1-piece (MS654114MF) spec sheet no longer shows a tank-to-wall measurement, so I would beware, although I think 1/2" is likely.
The Original Toto Drake (model CST744E or CST744EN and the like) can happily mount on just under 11 inches (i.e. 10-15/16" or so), so that's also one to look at. Indeed, that very-very popular toilet might even look a little better on 11.5 than it does on 12, because there is less space behind the tank to the wall on 11.5. Be sure to check out the look of the new tank on the "EN" version, because a lot of people seem to like it.
So now let's talk about skid marks. (Do we have to? I guess so...) Here's my take on it: People need something to bitch about, and you see a lot of that online. The Aquia is a washdown flush, which means that there is no siphon jet at the bottom of the bowl to power the flush. That siphon jet is a common feature in toilets, and it helps, but it also uses water -- water goes out of the tank and down the drain but never passes across the surface of the bowl. In a washdown flush, you get a big cascade of water -- all of the water used in the flush -- across the surface of the toilet bowl. This helps dislodge skid marks. Washdown flush toilets generally hold less water in bowl upon "refill" than do more-conventional toilets, so stuff has a greater chance of touching porcelain without first hitting water, which sometimes makes a difference in whether it attaches to the surface and needs to be dislodged (but, I'm here to tell you, even in 9-gallon toilets, sometimes it doesn't). So, on balance, you may have a little more of your business adhering to the Aquia before the flush, but then the flush is a pretty-darn-dramatic cascade of water (for a low-flow), so there's a greater chance of it cleaning off. It also depends, as is often pointed out here, on the (God help us) "consistency" of the stool.
Here's what I have found: a lot of people who are installing low-flows are replacing favorite old toilets where they poop into a swimming-pool-sized body of water, which, when flushed, lazily swirls its way around in the bowl before finally discharging 20 seconds later. When they start using a new toilet that doesn't put 2 gallons of water in the bowl to poop in, they find that OMG it's different, and some look to find fault, while others are amazed at how much can be done with 1.28 (or even 1.0) gpf!
That said, I have on rare occasion walked into a bathroom in our country home and discovered that the previous user had made a particularly-sticky deposit, and there was a skid mark or two sitting in the water of the bowl. You know what I do? I flush. After having sat there for hours, because of the solvent action of the water, it just comes right off and goes down and voila!, clean again. This happens about once every 100 visits.
The Aquia flushes very well, in terms of evacuating the waste in the bowl, and it does a good job of cleaning. You may find instructive the experience that our founder, Terry, relates. He has installed literally hundreds and hundreds of Aquias (and thousands of Totos) in his market. He says that the Aquias have the lowest return rate (less then 1/2 of 1 percent) of any toilets he installs. And, on top of that, he gets many, many, many customers who install one Aquia, and then call a month later and order more. That experience is pretty confidence-building to me. He also has very good experience with the Original Drake and the Drake II, as well as other Totos.
Gary Swart
Yakima, WA
For the occasional skid mark, I have found a couple of quick and easy solutions. First, a couple of facial tissues dropped in and immediately flushed often wipes the bowl clean. The other is a brush. A couple of quick swishes and a flush always works. If you have a constant problem, you might want to examine your diet.
Wallijonn
Arizona
It comes in a 10" rough-in, too.
The modular rough-in assembly has some play. Add the closet flange "play" and you can probably move it 3/4" - 1" forward.
For light streaks I find that a urine flush an hour later usually washes everything left away. For small "spotting" I may need to take a brush to it when it is very high above the water line.
