1/4 HardieBacker Board for Walls?
Discussion in 'Shower & Bathtub Forum & Blog' started by MAD King, Jul 13, 2013.
  1. MAD King
    MAD King New Member
    Mar 24, 2013
    Nashville, TN
    Hello,
    I have a lot of the 1/4 HardieBacker Cement Board left from floor tiling.
    When I put two together, can I use that for walls too?
    Thank you
  2. johnfrwhipple
    johnfrwhipple BATHROOM DESIGN & BUILD for both Canada & the US
    Jul 20, 2009
    Design Work World Wide: Bathrooms Vancouver Area
    North Vancouver, BC
    Never seen that done before. Maybe if the second sheet was thin-setted to the first it might fly. Might even be stronger....
    I think 1/4" is approved by the maker for wall tile but I would not trust it. If the two are bonded to each other I would bet you get a strong backer.
    JW
  4. MAD King
    MAD King New Member
    Mar 24, 2013
    Nashville, TN
    So you think if I would put a thinset between it would work and even be stronger? Theoretical it makes sense.
  5. johnfrwhipple
    Jul 20, 2009
    North Vancouver, BC
    You need all four sides of cement board secured with studs or blocking. With this in place I would bet that if you nailed off the first layer with some smaller nails and then installed the second layer with a slurry coat of something like Laticrete 254 your net result would be stronger than a 1/2" layer of Hardie. Why not buy one sheet of 1/2" and do a small test.
    Set up a deflection test. Might save you some money if you can find out it works.
    The board should not flex inward more than 1/4" between 16" on center walls studs.
    L/360 deflection for a 16" center wall stud is very low under 1/16". This is very hard to meet with any backer board.
    I would mock up a test and then add 100 lbs of weight on your mock up. Measure the sag. Then check the sag on a 1/2" board. If you are within these ranges I would think your fine.
    What type of waterproofing are you planning to use over this install. If your skipping any waterproofing then having fuller sheets and less seams would be the way to go...
    JW
  6. MAD King
    MAD King New Member
    Mar 24, 2013
    Nashville, TN
    I contacted Hardie Backer and that is what they wrote me back:
    THe do not recommend doubling them, but that doesn't mean that it can't be done to give a more sturdy application, right?
  7. johnfrwhipple
    Jul 20, 2009
    North Vancouver, BC
    Perhaps there is a expansion issue or directional expansion.....?
    Could you adding some extra blocking to bring your span's between joists down to 12" center's, then 1/4" plywood then 1/4" hardie? JW
  8. MAD King
    MAD King New Member
    Mar 24, 2013
    Nashville, TN
    Yes I could add a layer of plywood under, but that doesn't save me money. I have to buy the plywood first and I was trying to use the 1/4" hardie to save money.
  9. johnfrwhipple
    Jul 20, 2009
    North Vancouver, BC
    Then increase the blocking between studs and make sure you install the sheets the same way (directional). Scrap 2"x4" lumber is everywhere and will cost you nothing to pick up.
    You never answered my question about waterproofing.
    You need to finalize the complete system before jumping in....
  10. MAD King
    MAD King New Member
    Mar 24, 2013
    Nashville, TN
    Will do this with the studs and I don't know what type of waterproofing I will use yet.
    Thank you
  11. johnfrwhipple
    Jul 20, 2009
    North Vancouver, BC
    Are you building a tub and shower or just shower?
  12. MAD King
    MAD King New Member
    Mar 24, 2013
    Nashville, TN
    Both, but the tub area will be a lot later due the tight money. So this area will be empty until then.
  13. johnfrwhipple
    Jul 20, 2009
    North Vancouver, BC
    So the project at this point is just the shower. What kind of shower drain are you using? Is the shower base ready made or are you making a custom one?
    Adding waterproofing to the job you can easily expect to pay another $60-90+ to waterproof the walls from the pan to about 6'. Typically 3'x3' shower needs one gallon on liquid membrane or one unit of Ardex 8+9 to waterproof it.
    I would not skip this step. JW
  14. MAD King
    MAD King New Member
    Mar 24, 2013
    Nashville, TN
    I don't think you need a waterproof wall. There will be not water standing on the wall for a longer time (gravity).
    I will add as a barrier 15 roof felt behind the backerboard. For the pan I got the membrane. Shower drain is a Luxe which I bought when I still had a job. lol.
    I am making an own pan.
  15. johnfrwhipple
    Jul 20, 2009
    North Vancouver, BC
    I'd debate you on that point and caution you that with loads of off cuts and no topical waterproofing you might have a mess on your hands.
    JW
  16. MAD King
    MAD King New Member
    Mar 24, 2013
    Nashville, TN
    Physically a 15 roof felt between the studs and the cement board should be fine. If water runs behind grout and board it will be stopped by the felt and the liner of course.
    A membrane over the cement board is of course the better way or top of the line, but a felt behind will work also. Adding a membrane to the felt and leaving the cement board between like sandwich style, creates moisture.
    Correct me if I am wrong.
  17. johnfrwhipple
    Jul 20, 2009
    North Vancouver, BC
    MAd King your approaches are within industry guidelines and allowed by building codes. It's just your approach is the bare minimum approach. I can not answer your question with a simple one liner since there are so many variables. If your going to piece meal a load of scrap board you are incorporating a lot more area to absorb water.
    I would not go this route but rather the topical membrane approach.
    I wish you well and hope your shower is a success. I will not personally say "Great" sounds like a winner since it is not how we build our showers. I would remind you that you have already saved the money a container of of Ardex 8+9 or a bucket of Hydro Ban costs. That money could make your bathroom's shower waterproof - not water resistant. If you want to follow the base grade standard this of course is your choice but if you go that route I would be using full sheets of backer board. So your back to the start.
    Good Luck. JW
  18. MAD King
    MAD King New Member
    Mar 24, 2013
    Nashville, TN
    John,
    I was able to return the 1/4 hardibacker and got the 1/2 now. I didn't know that HomeDepot accepts returns after 90 days, but they kept the taxes, which I don't mind.
    For the waterproofing, can I also use Redguard from HomeDepot? I would have to order Ardex online, because I can't find it locally.
    Thank you
  19. johnfrwhipple
    Jul 20, 2009
    North Vancouver, BC
    This sounds like a better plan.
    When you install the backer board tape the seams and skim coat (flat trowel) the entire board. My testing has shown to me that the liquid membranes hold better over the thin-set than they do the backer board. Give the thin-set a few days to set up or use a self curing rapid setting thin-set and wait a day.
    JW
  20. MAD King
    MAD King New Member
    Mar 24, 2013
    Nashville, TN
    That is a good idea with the thinset. I also read that the Redgard can be thined upt to 50% for the first coat and then the second coat regular.
    They also say that with Redgard a non-modified thinset is recommended.
  21. johnfrwhipple
    Jul 20, 2009
    North Vancouver, BC
    Not sure I would do this. I have read that the incorporation of water to liquid membranes adds tiny air pockets and weakens the product. I'm doing a series of shear tests with uncoupling membranes and sheet membranes this week and later will be putting the liquids head to head. I'm going to see what affect the addition of water has on these when I do. I will at the same time test the varies backer boards at the same time for shear strength. If you can hold on a few weeks I'll have an answer for you. To be safe clean the backer board to remove any bond breakers and then burn in a good scratch coat of thin set.
    JW
Similar Threads: HardieBacker Board
Shower & Bathtub Forum & Blog FIBEROCK Tile Backerboard vs HardieBacker Cement Board Mar 15, 2013
Shower & Bathtub Forum & Blog Hardiebacker vs Greenboard Mar 16, 2010
Shower & Bathtub Forum & Blog Countersinking Backer-On screws in Hardiebacker? Jan 26, 2009
Shower & Bathtub Forum & Blog Two layers of cement board? Friday at 11:05 AM
Shower & Bathtub Forum & Blog Potential problem with cement board installation Jun 6, 2016
