faucet removal problem - please help
jennimac
Austin, TX
Hi y'all, i am replacing the faucet in my bathroom and having some trouble removing the old one. The old faucet is lifting off the vanity, but is still somehow connected to the water lines. I've removed the nuts and plastic nuts underneath (stubborn), and the handles/nuts from above. it doesn't look like there is anything more to disconnect, but the line and the faucet are still together. the faucet is probably about 20 years old - is it just stuck?
Any suggestions would be greatly appreciated. Thanks!
Plastic lines into the faucet body stuck?
Yeah, that's about it.
If you are removing the faucet anyway, just lift it out and use new supply lines.
If you plan on reusing what you have, then you need to pry them off.
Insurance companies don't like the plastic stops and supplies though.
jennimac
Austin, TX
Thanks Terry for the fast response and helpful suggestion. I worked at it, and they finally came loose. The washer that was holding it together was damaged, and i am told that assembly method is older and the washer may no longer be available. The supply line is one with the valve, so i suppose if i cannot find the washer, i'll need new supply lines and valves?
But let me not get ahead of myself - i'll first try to find the washers. :)
Thanks Again!
It really is prudent to replace the supply lines when replacing a faucet. If that means new valves, then those too. Bending them around after sitting for years is risky.
Jimbo
San Diego, CA
If you have corrugated supply lines integral with the stop valve, there was a very lengthy thread recently on that subject. Let me save you the pain of digging through it! You MUST replace those valves.
