Thanks for your additional input Stuff.
I did something this morning I should have done 2 weeks ago: I called Hansen Motor Co., manufacturer of the Synchron motor in question here. I spoke with an engineer and learned more than I ever really wanted to know. What I learned was consistent with most everything posted here, but I thought I’d present it anyhow.
Hansen's Synchron motor is a
hysteresis motor, or more accurately, a
hysteresis synchronous motor.
These motors are very different in design from an
induction motor with which I am most familiar. These motors are used where exact speed (assuming an exact-frequency AC source) and rotation with low flutter (high-frequency variation in speed) are essential. Their distinguishing feature is their rotor, which is a smooth cylinder of a magnetic alloy that stays magnetized, but can be demagnetized fairly easily as well as re-magnetized with poles in a new location. Hysteresis refers to how the magnetic flux in the metal lags behind the external magnetizing force. The angular lag between the rotor pole and he stator pole produces the
hysteresis torque. These motors have a stator like those of capacitor-run squirrel-cage induction motors. On startup, when slip decreases sufficiently, the rotor becomes magnetized by the stator's field, and the poles stay in place. The motor then runs at synchronous speed as if the rotor were a permanent magnet. When stopped and restarted, the poles are likely to form at different locations. For a given design, torque at synchronous speed is only relatively modest, and the motor can run at below synchronous speed. In simple words, it is lagging magnetic field behind magnetic flux.
Design features of the hysteresis motor lend themselves to the stalling mechanism used in a zone valve application. When the zone valve rotates to its physical stop at the open position, the motor simply stalls with current still applied. This condition generates a bit of heat but not enough to be detrimental to the motor, which is typically rated at tens of thousands of open/close cycles before failure.
Here are several useful links that explain the principle and workings of the hysteresis motor:
https://www.electrical4u.com/hysteresis-motor/
https://circuitglobe.com/hysteresis-motor.html
https://en.wikipedia.org/wiki/Synchronous_motor
