Zoeller pump for laundry tub in fish room
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by BHHOWARD, Aug 1, 2010.
  1. BHHOWARD
    BHHOWARD New Member
    Aug 1, 2010
    Hello,
    I am in the process of creating a room in my basement to house equipment for my salt water fish tanks. One item I'm adding is a laundry tub that will be used to clean equipment (fish poop, small amounts of sand, small amounts of carbon, and small amount of Granular Ferric Oxide (GFO) - small pebble-link grains), handle about 5 gallons of salt water per day during water changes, be used to dispose of RO waste water, and also handle the drain from a humidifier. I would like the laundry tub to drain into a basin that is on top of the concrete and that ejects into my sewage line. I was thinking about using a Zoeller pump. From this page, http://www.**************.com/drainsystem.html, I've identified a model that may meet my needs. The model is 131-0001. It has the M98 pump.
    Questions:
    1) Does this seem like a good fit for my needs?
    2) Is there any concerns about using this pump for the materials it will be handling?
    3) I have read in the past that Zoeller has used inferior switches that fail regularly after two years on some models. I have read that some plumbers are replacing the stock switch with a mercury swtich. Does this model have that issue? Where can I find the mercury switch?
    4) Does this basin seem big enough to safely handle 5 gallons of salt water that is automatically sent to the tub daily?
    I am also posting another question about a floor sucker model in another thread.
    Thanks for your advice,
    Brian
Similar Threads: Zoeller pump
Plumbing Forum, Professional & DIY Advice Superior pump vs Zoeller; Zoeller options Jan 19, 2017
Plumbing Forum, Professional & DIY Advice Which Zoeller sump pump to buy? Sep 2, 2011
Plumbing Forum, Professional & DIY Advice Zoeller pedestal sump pump Sep 1, 2011
Plumbing Forum, Professional & DIY Advice Utility Surface Pumps - Zoeller Vs. Wayne Aug 26, 2011
Plumbing Forum, Professional & DIY Advice Zoeller M264 stopped pumping Jan 26, 2010
