Your showerhead can kill you ...
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Agu, Sep 19, 2009.
  1. Agu
    Agu New Member
    May 21, 2009
    Tampa, FL
    Recent research found that mycobacterium avium lives in the majority of showerheads tested...
    http://www.reuters.com/article/lifestyleMolt/idUSTRE58E03U20090916
    Heard Dr Pace interviewed on NPR and he found that plastic showerheads/ plumbing harbored a significantly higher level of pathogens than metal showerheads/plumbing. The interesting part to me, as an aquarist, is that copper is an effective antipathogen in aquariums, to the point where it can kill not only parasites but also corals and invertebrates. Perhaps copper plumbing is not only efficient, but it also protects our health ?
  2. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    That is true.
    One of the good points of copper.
    It's funny because there is a lot of debate over what is best but really the answer is there is no perfect material and when it's invented I'll surly be using it. Really the answer is to select the best material for use in the particular application for best results.
  4. Master Plumber Mark
    Master Plumber Mark Master Plumber
    Feb 6, 2005
    Sensitivity trainer...healey-feeley.....
    damn...everything is trying to kill ya
    I cant even play with my rubber duckie
    in the shower any more without worrying
    about getting blasted with bacteria...
    quack .....quack..
    I would think that the chlorine in the water would just about kill anything in the plumbing system....but then their are people complaining about the high levels of chlorine killing you too...
    everything is unsafe out there...
    Redwood., what are we all gonna do??
    save me.....save me......:D
  5. seaofnames
    seaofnames DIY Senior Member
    Jan 25, 2009
    Boilermaker
    Mission, BC
    Run pex and have copper stub outs!! So you have the best of both worlds!!
    Just another scare tactic that you cant do much about unless you are a germaphobe.
  6. Ian Gills
    Jul 24, 2007
    USA
    Sod you lot. I am going back to lead.
    There must have been some advantages to using it.
    Anybody?
  7. Cookie
    Cookie .
    Oct 7, 2005
    You don't have to worry about paying for college. :)
  8. Cass
    Cass Plumber
    Nov 12, 2005
    You lost your mind s.l.o.w.l.y...with lead pipe...I just was looking at a leaking lead pipe the other day...I told the guy that the whole line needed to be replaced...he had no Idea that his main supply line was lead...
  9. Runs with bison
    Runs with bison Member
    Aug 23, 2009
    Midwest
    It's hard to see this as a serious threat, and it is one that can be controlled/reduced. Consider a couple of things for a moment to put the results in perspective:
    1. Who puts their face into the initial stream of water from the showerhead? Nobody that I know of (with an asterisk *) Okay, so if the concentration is 100 times higher in that initial rush of water where does most of it end up? Down the drain. So perhaps the level is still elevated by the time the shower taker is actually wetting face and hair, but it is likely to be at worst a few times greater than normal tap water. If so then it is not any more of a threat.
    2. There should be several ways of reducing the concentration. One that was already mentioned was using a metal showerhead. But it would also seem that doing the intial warm up of the shower with full hot would also be helpful in chasing out the worst of the nasties. Warming this way is faster and actually uses less water (and perhaps less water heating) because it doesn't waste cold water in the mix. Those who are really paranoid could let it run somewhat longer in hot only mode...
    3. Using a non-aerating showerhead should eliminate the worst of the minute suspended droplets that are the real cause for concern.
    4. It was the largest municipal systems that had the problems, not smaller systems and wells.
    * The two things this does make me wonder about are recirc systems and tub/shower diverters. With both the shower head will have relatively little flow through it before the water reaches temp. (With the tub/shower diverter one is inclined to warm up rapidly through the higher flow tub spout, and do the initial temp setting there.) In those cases one might be more likely to be doused with higher concentration of bacteria.
    A direct link is: http://www.colorado.edu/news/r/50fe20a5a5376631bbad2024f89b02c0.html This includes video.
  10. Ian Gills
    Jul 24, 2007
    USA
    Looks like I'll be answering the lead pipe question myself.
    Lead is actually more expensive than copper which is another reason people do not use it for pipework.
    Its main advantages were corrosion resistance and ease of manipulation. In fact it is still used in specialist applications that require these features e.g. laboratory plumbing.
Similar Threads: showerhead kill
Plumbing Forum, Professional & DIY Advice Remove Delta Showerhead flow restrictor Apr 3, 2016
Plumbing Forum, Professional & DIY Advice Moen showerhead maybe 3669EP Dec 12, 2014
Plumbing Forum, Professional & DIY Advice Need recommendation for Low Flow toilet, showerhead, and aerator for apartments May 15, 2014
Plumbing Forum, Professional & DIY Advice Quality multi-function handheld showerhead with pause function Apr 11, 2014
Plumbing Forum, Professional & DIY Advice Removing Low Flow Restrictor on Kohler Showerhead Nov 12, 2013
