Hi, all, longtime lurker, first time poster.
Our house is on a community well and we just have a copper stub coming into the house. The water is tested every year and very good as far as unsafe chemicals + bacteria, but the water is pretty hard and has a low amount of iron. For the past 2 years, we've had the "old setup" below. This "old setup" had clear water, the only problem was having to frequently change out the 2.5" x 10" cartridge filter.
To reduce filter changing maintenance, we switched to a whirlpool central water filtration unit with auto-cleaning and installed it with a mesh screen spindown prefilter. During this time, we also switched from using potassium chloride to Morton's rust remover salt (green bag). A few months later, we're now noticing yellow'ish water in the toilet that's darkest after the softener regenerates and clears up to a very light yellow after 20-30 gallons are flushed through the water lines.
My thought is that 1) the Rust Remover Salt dislodges built up iron in the softener and making its way past the whirlpool filter, or 2) the Whirlpool filter isn't filtering as it should. My first step was trying a round of Iron Out in the brine well to clean the softener and then switch to normal salt (Morton's yellow bag) instead of rust remover.
Does this sound reasonable? What else should I be looking at?
Old setup
Well water in -> Pleated Cartridge Filter -> Water Softener w/ Potassium Chloride -> House
New setup - (yellow water a few months after install + salt switch)
Well water in -> Spindown filter -> Water Softener w/ Rust Remover Salt -> Whirlpool Filtration Unit -> House
Old setup
