Wood Laminate Flooring Over Ceramic Tile
Kiko
Royal Oak, Michigan
My brother was told by Home Depot that they wouldn't install a wood laminate floor over his ceramic tile in his kitchen unless: (A) they removed the existing tile floor ($1400) or (B) they applied a self-leveling skim coat to fill in the grout lines ($1200).
I am under the impression that these floating floors use some sort of a foam underlayment that should fill in the small recesses caused by the grout lines.
If this is true, we can install it ourselves. My question then is how to attach this foam underlayment to the tile, since you obviously can't just nail it. Is there an adhesive foam underlayment for ceramic tile?
Each manufacturer has their own limits on flatness. On the floating floor I did install, neither the foam nor the top layer (mine was actually wood but installed and locked together like many laminates) are often attached to anything. So, if yours is like mine, you don't need to attach anything to anything. The distributed weight of the whole thing and the friction between the laminate and the foam and the foam to the floor keep it in place.
I will, though, again warn you about the overall flatness...it is pretty strict, and your tile may or may not actually be flat enough. Many tile has a slight dome shape, and the grout may not be level with the top of the tile. Plus, at least on the one I installed, it had to be flat to within 1/8" over 10'. If an edge happened to align with that low point, you might delaminate the flooring which is the reason they want it really flat. Some will allow you to use something like a layer(s) of roofing felt to help fill in a depression (sort of like contour lines on a topographic map), but a hump could be lethal to the floor.
This is more a question of contacting the manufacturer and reading the instructions carefully. If the overall tile floor is flat enough, squeegeeing in a leveler to fill in the grout areas shouldn't be all that hard to do.
Verify with the manufacturer what their recommendation are.
Cutting laminate material requires a very sharp blade
Dj2
California
Any manufacturer will tell you to lay laminate on a flat surface because the foam moisture barrier can't fill grout spaces.
HD offers to skim the floor with self leveling mortar - if you don't mind the added height to the floor, this is what you should do.
Kiko
Royal Oak, Michigan
Thanks jad and dj2.
IMO, the easiest way to deal with minor grout indentations would be some kind of seam tape - either rigid or perhaps with a narrow band of foam in the middle that could fill the grout spaces.
Maybe I'm just dreaming. :cool:
Cacher_Chick
Test, Don't Guess!
With many laminates, compression from normal foot traffic will eventually cause any underlaying ridge or contour (like a grout line) to become visible through the laminate, even with the foam underlayment in place. We often see this where screw holes or knots are left in the underlayment without being filled. Not sweeping the underlayment clean of tiny debris can give bad results also.
Colbyhuston
Franklin, MA
Its good that first they removed the existing floor, because it will be better if they level the floor first and make a flat surface. Then by applying the laminate flooring it will look more better.
snokel
Wi
That's funny because I want to do just the opposite, get rid of the laminate in the kitchen and put down tile, laminate in a kitchen is horrible IMO.
snokel
Wi
Not that I think laminate is a good idea in the kitchen, but could'nt they just fill the grout lines with more grout so it's level?
Grout in thin horizontal layers isn't very strong, so it's doubtful you could get grout to stick and stay in place.
snokel
Wi
true but with something on top of it, it might work. or what about filing the grout lines with a self leveling polyurathane concrete crack filler?
Michal Adam
Las Vegas, NV
For a beautiful and perfect tile installation, you need to ensure that every facet of the job is completed properly according to tile industry standards and best practices. And don't forget to ask always the manufacturer.
