Wirsbo / Uponor Installation Question
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by craigs, Jul 26, 2008.
  1. craigs
    craigs New Member
    Jul 26, 2008
    I M repiping my house with Wirsbo / Uponor. The inspector told me that he wanted all the pipes under the house insulated. I also need to secure it every 32 inches. The problem is that the floor framing is post and beam 6 foot on center with 4 x 8 beams. Car decking sub floor. I do not want to drill through the beams if at all possible. Would it be OK to hang, under the beams, 1 x 3 ? Then insulate the Wirsbo and zip strap the works to the 1 x 3 for the runs across the house?
  2. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    I doubt he'd like tubing zip tied to a 1 X 3...
    Why not use products designed for the job... Here are a few of them
    [​IMG] [​IMG]
    [​IMG] [​IMG]
    Why not consider a few feet of extra tubing to follow beams?
    or, a bit more expensive than that...
  4. Redwood
    Dec 15, 2007
    Service Plumber
  5. craigs
    craigs New Member
    Jul 26, 2008
    I have and do use the nail pipe clamps. This install however is the first time I have never had a floor joists system to nail to. The girders are spaced 6 feet apart. Being the weekend I cannot talk to the inspector and wanted to be finished with the rough in. Thank U. Craig
  6. Redwood
    Dec 15, 2007
    Service Plumber
    Those Watts clip rails are 6 1/2' long.
  7. hj
    hangers
    Use a 1x4. Put the insulation on the tubing, then use a 2 hole pipe clamp large enough to fit over the insulation and then screw that to the 1x4.
  8. craigs
    craigs New Member
    Jul 26, 2008
    Thank U very much. That worked great. Craig
Similar Threads: Wirsbo Uponor
Plumbing Forum, Professional & DIY Advice Replacing Wirsbo Control Type 514 with Uponor A3031004. Feb 5, 2015
Plumbing Forum, Professional & DIY Advice Wirsbo/Uponor PEX & future work Feb 21, 2013
Plumbing Forum, Professional & DIY Advice Wirsbo / Uponor Pex Air Expander Tool Dec 28, 2009
Plumbing Forum, Professional & DIY Advice Pex Wirsbo uponor tool Sep 21, 2009
Plumbing Forum, Professional & DIY Advice Wirsbo (Uponor) fitting difference? Apr 20, 2009
