Wiring size for upgraded hot tub
Discussion in 'Electrical Forum discussion & Blog' started by JWR-1, Nov 16, 2007.
  1. JWR-1
    JWR-1 New Member
    Nov 16, 2007
    I am replacing an existing hot tub with a new one. The new tub requires an electrical service of 240V 60amp. I have upgraded my circuit breakers at the panel and installed a 60 amp GFCI. Currently I am wired using 8awg. Will this wiring be sufficient for a 50' run? Or do I need to upgrade to a #6awg wire?
    Thanks for the help.
    JWR
  2. Bob NH
    Bob NH In the Trades
    Oct 20, 2005
    New Hampshire
    Ref: NEC Table 310.16
    8 AWG is rated for 50 Amps if it is not NM or other 60 C wire.
    You need 6 AWG in THWN for outside. You can usually use 8 AWG for the neutral and 10 AWG for the ground unless your inspector gets picky. My last one didn't bother with code and wanted 8 for the ground.
    It will all fit in a 3/4 conduit.
Similar Threads: Wiring size
Electrical Forum discussion & Blog Need help wiring ceiling fan! Feb 15, 2017
Electrical Forum discussion & Blog Strange Dimmer Switch Wiring Jan 6, 2017
Electrical Forum discussion & Blog Doorbell Wiring Dec 29, 2016
Electrical Forum discussion & Blog Advice for wiring 2 baseboard heaters Dec 16, 2016
Electrical Forum discussion & Blog Question about Ceiling Fan wiring Nov 9, 2016
