Wire size for 120V water heater?
Discussion in 'Electrical Forum discussion & Blog' started by Artie, Oct 3, 2010.
  1. Artie
    Artie New Member
    Nov 6, 2009
    Jacksonville, Fl
    I want to run this water heater, (10 gal., 120VAC, 1650W), at a remote location. (Approximately 20ft. from the breaker box.) Would 12-2 be sufficient?
  2. jimbo
    jimbo Plumber
    San Diego, CA
    1650 watts is about 13 amps. 12 guage wire is fine.
  4. Thatguy
    Thatguy Homeowner
    Aug 27, 2008
    A bounty hunter like in "Raising Arizona"
    MD
    If you have an ohmmeter, before you install this heater check that the element resistance is at approx. (120v^2)/1650w = 8.7 ohms.
    It can't hurt to make sure.
    Their kwh rating for a year is based on it being on 17% of the time. I guess this is some consumer average usage.
  5. Artie
    Artie New Member
    Nov 6, 2009
    Jacksonville, Fl
    Thanks guys.
  6. hj
    The KW for a heater is the "actual" wattage, not a "kw per year" statistic. The "kw/yr" number creates the "annual cost of operating the heater" which is a completely different thing.
  7. Thatguy
    Thatguy Homeowner
    Aug 27, 2008
    MD
    Speaking of power usage,
    since the element runs on 120v, wiring an electromechanical analog clock across the element for 24 hours or so will tell the heat loss through his R8 insulation.
    If the clock advances 5 minutes every 600 minutes with no hot water being used then his loss is 1650w(5m/600m) = 14 w = 48 BTU/hr.
    I definitely have to find a day job. . .:)
  8. Artie
    Artie New Member
    Nov 6, 2009
    Jacksonville, Fl
    Thanks. 1650 is the "watts @ 120VAC". 2523 is the Kw hours per year.
  9. jwelectric
    jwelectric Electrical Contractor/Instructor
    Jun 14, 2007
    Instructor
    North Carolina
    A #12 on a 20 amp breaker is just what the doctor (NEC) ordered.
  10. Jim Port
    Jim Port Electrical Contractor
    Aug 22, 2009
    Maryland
    Do you really think all this effort is worth it? Do you really think someone wants to go without hot water just to find out heat loss? Since heat loss should already be figured into the operating cost the energy star label should already tell whether the heater is efficient compared to other heaters.
  11. nukeman
    nukeman Nuclear Engineer
    Nov 20, 2009
    Nuclear Engineer
    VA
    It is only something us engineer types would be interested in. :)
    Anyway, if the OP wanted to know the heat loss, there is no need to do the test for 24hr. You could simply do it say overnight (or while at work). Just need to ratio the time the clock runs to the total time that has past and multiply by the heater power. Testing over a longer time would give a better average heat loss estimate, but the loss shouldn't change much unless you have the WH in an unconditioned space such as an attic or garage. In this case, the heat loss can be quite different than what the unit is spec'd at depending on climate and time of day/year.
    The test doesn't get you much except for the knowledge of how much heat is being lost. It is good info to have as a baseline to see what impact insulating the piping, replacing with a new unit, etc. has. You could also use this to show others (and yourself) that the standby loss in a tank-type WH (especially electric ones) is quite small and that a tankless type is not going to save a ton of money by not "heating water around the clock".
  12. Thatguy
    Thatguy Homeowner
    Aug 27, 2008
    MD
    Mr. Port, as a courtesy to you I must tell you that you are on my ignore list.
    If this were the real world you would, right now, be a defendant in an action for harassment and defamation, at the very least.
  13. ballvalve
    Dec 28, 2009
    northfork, california
    If he is on your ignore list, be sure not to respond when he defames you again.
    But I am more on Mr. Ports side. No one has the time for that except a high school energy class.
    Tankless water heaters are pretty much a joke when compared to an electric rig. You can bury an electric water heater in all your old winter jackets and get the standby losses to near zero.
    And I think the Indian-Indonesian anti-defamation league will soon be contacting you about that kid in a bowl about to be eaten by a snake.
  14. hj
    A 24 hour reading would only tell you the TOTAL time the heater ran, including replenishing the hot water used, unless the system were not used during that time period. If the heater is in an "unconditioned location" such as a garage, the heat loss will fluctuate according to the ambient temperature, which could change hourly, and would definitely change during the various seasons.
  15. Artie
    Artie New Member
    Nov 6, 2009
    Jacksonville, Fl
    I'm interested in all opinions here. My situation is that this old house's water heater is too far from the kitchen sink. I hate the fact that I must wait 5 minutes to get hot water from the kitchen sink. I was thinking of doing a small dedicated heater just for the sink. On the other hand, I don't want to spend $400/yr to do that. But I might, for the "luxury" of psuedo-instant hot water. All opinions and ideas welcome. :confused:
  16. Jim Port
    Aug 22, 2009
    Maryland
    You could see about adding a recirculator pump on the hot water line. This way you should not need to wait so long for hot water.
  17. Thatguy
    Thatguy Homeowner
    Aug 27, 2008
    MD
  18. ballvalve
    Dec 28, 2009
    Its a pity that a 10 gallon water heater costs more than a 50 gallon job.
    You can find a 20 gallon mobile home one for 250$ or look at motor home water heaters, and get a small 120 volt element, maybe 1200 or 1500 watts, and you could plug it in under the sink without more wiring. That would likely be cheaper than a recirc system, and you can super insulate the unit too.
    If you use a lot of water at that sink, your incoming cold could be the HOT in from the water heater. That should fill in the "lag" time
  19. Thatguy
    Thatguy Homeowner
    Aug 27, 2008
    MD
    You only have to make up 1 gallon of cold water per 100' of 1/2" ID pipe. It's ~800 BTU for a 90F rise, so using 1200 W it'd take ~11 minutes to recover.
    You probably have the whole morning to recover. A 120w heater will take 1.8 hours to recover.
    Decide on what tradeoffs you can make and then hope somebody makes a heater that does this.
    8.3 pounds/gal
    90 F rise
    747 =BTU
    according to
    http://www.onlineconversion.com/
    this many BTU per hour equals
    219 watts
    with 1200 w
    this takes
    0.1825 hour
    10.95 =minutes
  20. ballvalve
    Dec 28, 2009
    Right, so a 1200w or less 5 or 10 gallon WH under his sink, with the hot from normal heater as infeed would solve his issue pretty cheaply with less issues than recirc.
    Would also keep his undersink warm and dry, an advantage toward cabinet survival.
  21. Thatguy
    Thatguy Homeowner
    Aug 27, 2008
    MD
    Yes, I hope we find out how it finally worked out. The OP certainly has all the facts by now.
    Mr. Valve, you are definitely not a run-of-the-mill electrician.
    Good. You can make up for the [name deleted] types in this world.
Similar Threads: Wire size
Electrical Forum discussion & Blog What size wire for a 230 volt 20 amp breaker? Jun 14, 2015
Electrical Forum discussion & Blog Breaker and wire size for pool heat pump - MCA, wire and breaker size. Feb 28, 2014
Electrical Forum discussion & Blog Wire size, 3ph Delta, 120/240 Jul 10, 2012
Electrical Forum discussion & Blog Wire size Feb 20, 2012
Electrical Forum discussion & Blog Neutral wire size smaller than hots for 100 amp subpanel? Feb 10, 2012
