Why my expansion tank keep failing?
Navien Hater
Alberta
Hi there,
My first expansion tank with the Navien tankless water-heating system was leaking in about 2 years so I replaced it with a new Calefactio HGT-30-4.8 us gal tank 9 months ago. However, I just found out today, it is leaking again, not event last 1 year?!!!! I have no idea that is the problem of Navien water-heating system or just the low quality of the tanks?
I know I have to replace the tank, again, but just want to get some opinion if my Navien failed me again!!!
Thanks for reading!!!
John Gayewski
Iowa
Hi there,
Tankless heaters don't actually need expansion tanks. I didn't search the tank you had, but the ones that are used with tankless heaters are tiny, they look more like a hammer arrestor.
What do you mean fall? How are they failing? Your saying leaking, but where?
Bannerman
Ontario, Canada
Post some photos showing the expansion tank connection and showing any tank support brackets, straps etc. Also include a diagram showing the location of the expansion tank in relation to the Navien unit.
Water source: Private well or municipal supply?
Was the expansion tank air pre-charge pressure adjusted in relation to the water pressure normally experienced in your home?
Navien Hater
Alberta
Sorry, it is "fail", my bad. A company installed the Navien combi-boiler. Its not a tiny system so they added a expansion tanks for me.
Navien Hater
Alberta
Navien Hater
Alberta
sure, photos are one the way... the green one is the old one which I replaced 9 months ago during the whole system down...
Navien Hater
Alberta
First test the boiler water for ph with litmus paper or another way. Ex tanks like other parts normally don't fail that way. Bladder yes not the tank especially two different brands.
You are right. It should last 5-10 years not 9 months! thanks
