Why can't I Dry-fit PVC fittings?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by sjb8112, Jun 14, 2005.
  1. sjb8112
    sjb8112 New Member
    Jun 14, 2005
    What is the trick to being able to dry-fit PVC fittings before final assembly? I am working with 3" PVC fittings from Lowes, plumbing up the waste line to the new toilet location in our bathroom remodel. I'd like to put the three fittings together and mark them before I get out the cement so that I can be sure the slope of the line is correct and that the closet bend is going to be in the exact right position, height, and level once the cement sets. But, the fittings just don't slide together -- If I really work at it, I can get them seated about halfway, but that's not good enough.
    Once I put primer and cement on them, they slide right together and seat all the way, so I don't think there's anything wrong with the fittings.
    I only get one shot at this, and if I mess it up I'm going to be cutting into the ceiling and wall in the room below the bath to get at the tee that I ruin on the stack.
  2. hj
    pvc
    That is the way it is supposed to work. PVC joints are called "interferrence fit" which means they are tight when dry so there is no excess space that has to be filled with cement when they are assembled. If you remove any roughness on the end of the pipe, you may get them together a little further, but if they fit all the way, when dry, the joints would not be good enough once it is assembled.
  4. jimbo
    jimbo Plumber
    Well, this is why Do-it-Yourself sometimes becomes Do-it-Over. Some things are learned only be experience. Your only cost will be to replace some fittings if you don't get it just right the first time. If time is valuable to you or at a premium, then this is where you hire someone who will get it right the first time.
    This is not meant to be a criticism of DIY, because at home I tackle any job in any trade. Some jobs go better than others, and I just accept that fact.
  5. captwally
    captwally New Member
    Apr 30, 2005
    Apartment Complex Maintenance, Professional Chef
    Florida
    The reason PVC cement is called "solvent weld" is exactly the reason the facts have been stated by knowledgeable people before I got to the thread. PVC fittings are not 'glued' together, they are welded with the cement. The glue is not actually a separate entity connecting two parts, rather it is a solvent that chemically liquifies the PVC itself creating a bond that in effect is melting the parts together.
    The parts do not fit together dry because the tolerances are so thin to make an effective joint. When the 'glue' is applied, the parts slide together all the way because the plastic has actually been melted at the point of connection. Once that connection cures, it is essentially one solid piece of PVC, not two pieces glued together.
    If you want to ensure a proper fit you must measure and cut where the fittings will be in the final assembly, not in a dry fit situation.
  6. SteV8e
    SteV8e Mechanical Engineer
    Nov 16, 2006
    Mechanical Engineer
    Minneapolis, MN
    I ran into that dry-fit problem too. My application is different because I am using the pvc to build frames. My son and I are building a trebuchet and the frames will be 2" pvc. The treb will be made of two complex 3D frames that are a mirror image of one another. Each half includes a double wye, 4 90elbows, 4 45elbows, 2 Tees, and 2 adapters with square-head plugs (the frame will be filled with water for lauch stablility).
    Because of the complexity and not dry fitting, it is hard to build. If I had 3D CAD models of the fittings, I would know the exact lengths of the pvc pipe needed. Does anyone know if there are CAD models available?
    I am doing this project with my son to teach him some engineering and applied math. He is interested in hurling objects long distances.
    Thanks
  7. prashster
    prashster New Member
    Dec 7, 2005
    PVC pipe is also slightly flexible so usually putting the pipe next to the fitting and marking will give a good enough measurement.
  8. jadnashua
    Many of the fittings have a definite lip inside them. You should be able to insert the pipe in the fitting until it bottoms against that ridge or lip once it is primed and slobbered with the solvent.
    Don't overload the pvc, it can shatter into some nasty shards if you exceed its strength. It will bend a bunch first, though ,and is sensitive to temperature. Also note, it changes length a fair amount with temperature.
  9. hj
    measure
    That is why they make rulers so you can calculate the fitting's dimensions as far as insertion depth.
  10. Phil H2
    Phil H2 New Member
    Sep 12, 2006
    Tujunga, CA
    I don't know if PVC fittings have standard dimensions (galv/blk iron have standard running length dimensions, copper fittings do not and they vary from one manufacture to the next). If you know the fitting manufacture, you could check their website to see if they have CAD models. Spears Manufacturing has dimensions for their PVC fittings on the web (http://www.spearsmfg.com/).
  11. SteV8e
    Nov 16, 2006
    Mechanical Engineer
    Minneapolis, MN
    Phil:
    Thanks for the link to Spears; it has detailed dimensions for the fittings. I had received some specs from McMaster-Carr for the manufacturere Nibco, but not as detailed as the Spears drawings.
    I had to delete the ) from the end of the Spears link to get it work.
    I think that I will need to make the ProE CAD files myself. Let me know if you would like me to send them to you.
  12. ToolsRMe
    ToolsRMe New Member
    Mar 12, 2006
    CO
    Can you use ABS instead of PVC?
  13. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    You can't dry fit ABS either.
  14. ToolsRMe
    ToolsRMe New Member
    Mar 12, 2006
    CO
    I've installed a central vacuum system in my house and routinely dry fit the ABS stuff.
    Now that may be different than the ABS you use for water plumbing since I needed to get that stuff at a vacuum cleaner store.
    Live and learn.
  15. Mikey
    Nov 8, 2005
    Consumer
    Northern Washington
    My central vac used PVC, not ABS, but it was dry-fittable as well. In fact, I installed a large part of the system by dry-fitting and taping the outside of the joints with electrical tape. (It was temporary, waiting for some other construction to be completed.) It's a special thin-wall pipe designed to maximize the inside area for the outside diameter. Fits are sloppy, but once welded they're pretty strong.
  16. Gary Swart
    Sep 1, 2004
    Yakima WA
    The PVC used for vacuum systems is not the same as that used for drains. Go back up this thread and read HJ's reply regarding how PVC pipe/fittings are made and fit. Fitting PVC is really no different than fitting copper. I use a marking pen when working with PVC and copper to mark where I will cut the pipe. It's really not rocket science.
  17. SteV8e
    Nov 16, 2006
    Mechanical Engineer
    Minneapolis, MN
    I was not able to find any 3D CAD models for PVC/ABS fittings, so I made the ones I needed. Let me know if you would like me to share them with you.
    One might not use them when laying out a drain, but with something more sophisticated (central vac) or a frame like I am building, they will be very handy. I will know the lengths of all my cuts and do them all up-front; no dry fitting needed.
    I've tried to attach .pdf files to show a fitting and the frame, but the file is too large and the distiller I am using doesn't allow me to change the file size.
  18. krifos
    krifos New Member
    Dec 21, 2006
    dry fit
    If it is really that critical, try cutting off of the 75% of each hub on elbows tee,s etc. With most of the hub removed you should be able to make a dry fit model of what you need . After this you can replace the "test" fittings with new one's and be confident that you will have good results. Pvc is cheap enough to allow you to do this.
  19. student1
    student1 New Member
    Dec 7, 2006
    Ontario, Canada
    That ain't gonna do you any good. The reason you can't dry-fit is because the socket is tapered down to an interference fit. My 2c.
  20. Randyj
    Randyj Master Plumber
    Nov 25, 2006
    Alabama
    like hj said... measure the depth of the socket and use this to calculate the length needed. If you slop the glue on really good it will slip all the way to the stop... not rocket science.
  21. hj
    frame
    One thing, if you cut two of everything the two sides will be equal, and it is likely that some pipes, such as the legs, will be the same on a single side. I cannot see how a 1/4" even would make a difference, especially since I do not think you will be launching dishwashers or washing machines.
Similar Threads: can't Dry-fit
Plumbing Forum, Professional & DIY Advice Kitchen faucet removal. Can't get nut off. Feb 2, 2017
Plumbing Forum, Professional & DIY Advice Can't figure out where smell is coming from in bathroom Jan 13, 2017
Plumbing Forum, Professional & DIY Advice Can't find this sink clip Nov 7, 2016
Plumbing Forum, Professional & DIY Advice Can't figure out knocking pipes... Oct 31, 2016
Plumbing Forum, Professional & DIY Advice Can't figure out what this sound is. Help? Aug 26, 2016
